Old 05-01-2016, 08:55 PM   #1
Orion's Avatar
Using solar plug for trickle charger
We are picking up a new flagstaff micro lite with the figure 8 solar plug.
Assuming the solar panel you can buy has a controller and the plug is a direct connection to the battery can you just plug a trickle charger in for when it's stored? Has anyone done it?
Sent from my iPad 18 using Forest River Forums
2017 Flagstaff FLT21DS
2011 Tundra Platinum, 5.7l, 2WD, Firestone bags...
Orion is offline   Reply With Quote
Old 05-01-2016, 09:16 PM   #2
Flybob's Avatar
Little confused by the question, Figure 8 is a style of wire and doesn't specify a connector. Most solar panels come with MC4 connectors on the wires or pig tails. You will need to MC4 connectors to the figure 8 cable if there are no connectors. What controller do you have or plan to use? Most controllers have bare wire connections. Output from controller to battery will again be via bare wire connection at controller.
MC4 connector photo below.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-02-2016, 06:52 AM   #3
2007 WildCat 32QBBS
05CrewDually's Avatar
I don't see why not. Use a multimeter and check the plug voltage. If it matches battery volts then your good.
05CrewDually is offline   Reply With Quote
solar
