Originally Posted by wbdvt
I may getting very technical here but the transformer on the pole outside of your house is not a tap changer one.
The post never said 'that' local transformer has a tap charger. The post said where voltages are adjusted.
View a wire from the pole's top to the transformer. Follow that wire back to another transformer. That is where your voltage is regulated.
That 'another' transformer changes voltages often during the day. For example, since there are many transformers farther down the line (fed by the 'another' transformer), then 'another' transformer must increase voltage maybe in the morning to provide enough voltage for other and more distant pole transformers. he OP would observe voltage increase from 118 to 125.
A wire on top a pole transformer connects to a wire highest on the pole. Follow that wire back to the 'another' transformer that does voltage changes. If closer to 'another' transformer, then household voltages might vary more so that voltages farther down the wire remain more constant during the day.
