06-29-2014, 10:32 PM
Take The Road Less Travld
Voltage Too High
I started looking into adding the built in surge protector for my trailer. After reading up on the details, I learned that it auto shuts off and kills power to your trailer after reaching 128 volts. This raised a few flags as I have seen numbers above that in the past but never really thought anything of it. I right away tested the TT-30 in my garage and it metered 130-132 depending on the time of day. Well, this isn't going to work, the surge protector will never even turn on when I plug it into the Garage.
I did some more research and found that this isn't really good for my appliances at all and that it may cause damage when reaching ranges over 125 or so. I spoke with someone about the details and found out that my entire house was running this high at the recepticals.
I tested at the panel using a volt meter putting the ground on several different points on the neutral\ground bar in the panel and testing different power sources on different breakers. Some read 128 and others read 130. I was told my only option was to call the power company and they would have to fix it at the pole. I also read something about this could be caused by a bad neutral\ground in my house.
Before calling the power company, I wanted to check here and see what others had to say and maybe what else I can check if anything.
thanks
"Take The Road Less Traveled"
2020 Cherokee 294BH
2021 Chevy Silverado 2500HD 6.6 Duramax Diesel
I've been an RVer since 2007, Lifetime Camper
Gotta love the Outdoors, Disconnect and Enjoy Nature!
06-29-2014, 10:50 PM
I just experienced that at my house, my fridge sounded funny one day and I found 140 at the outlets. I called the power company, they sent a truck out, they tested my neutral, said it was fine. As they were at the pole the voltage dropped to 124. They said they didn't change anything but apparently something happened.
06-29-2014, 10:52 PM
Ha! Sounds like to me they fixed something or just cleaned off the dust on the transformer.
2020 Cherokee 294BH
06-29-2014, 10:55 PM
Either they fixed something or accidentally tightened something up. It's still solid so I'm good.
06-30-2014, 07:38 AM
Yep; transformer issue.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
06-30-2014, 08:45 AM
Utilities are allowed to have two utilization voltage ranges:
Range A is normal operation and is 120V +/- 5%
Range B is supposed to be of limited extent, frequency and duration. It is 120V with the range of +6% to -13%.
2016 Chevy Silverado 2500HD Duramax LTZ Z71 Extended Cab, Long bed
2012 Dodge Ram 1500 5.7L Hemi (with K&N Air Intake) (traded)
2012 Rockwood 2109S (Sold)
2014 Cougar X-Lite 21RBS
06-30-2014, 08:47 AM
Same issue a few years ago
We had the same issues a few years back. Our light bulbs seemed brighter in the house and were burning out more than expected. Also, when the clothes dryer started, there was a noticeable thump. I then checked the receptacles with a multimeter and found it to be in the 140 volt range. Spoke to an electrician friend who stopped in and checked the voltage at the panel. He said it was definitely on the power company line. Called the power company and they had someone over fairly quickly and changed the transformer. No issues since then.
Bill
2012 GreyWolf 18rb
2011 Dodge Ram 5.7 Hemi
Equalizer Hitch
07-01-2014, 09:53 AM
View a wire from the pole's top to the transformer. Follow that wire back to another transformer. That is where your voltage is regulated. Inside, it changes taps (adjusts voltage) so that yours remains around 120 volts. Doing many adjustments daily.
Voltage that high is not great for appliances. But will not cause damage. However incandescent bulbs would be failing at well less than half their rated hours.
Key is whether bulbs change intensity when major appliances power cycle. In most cases, this is an interior wiring problem. In rare cases, this is a major human safety issue. For example, fortunately no one was home when that fault caused a gas meter explosion.
But a constant high voltage is a problem at that transformer far from you house and often surrounded by a very high chain line fence.
07-06-2014, 10:26 PM
So the electric company came out and tested. Everything was fine. It was at 118 when he tested it. When I got home, I tested the same plug he tested and was getting a 130. I went to a friends house a few blocks away and was getting the same reading. Now I need to order a new volt meter before I'll know for sure.
2020 Cherokee 294BH
07-07-2014, 06:39 AM
The cheap ones do have a + range. Some are really big...
07-07-2014, 08:49 AM
How much of a time difference was it between the utility guy measuring the voltage and you measuring the voltage? The line loading could have changed such that the voltage is really high. If the line voltage regulator for the power line that feeds your home is goofy, there may not be proper regulation. I've seen it many times.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
07-07-2014, 06:17 PM
There was about 5 hours difference. I was worried about the the load difference too which is why I'm going to get a new or borrowed one just to check.
2020 Cherokee 294BH
07-07-2014, 08:46 PM
Probably a good idea. 130v is way outside the 120v+/-5%. You really need to monitor this until you can confirm whats going on. Highest I remember is 132v, due to a faulty regulator. My company paid a lot of $ for personal propery that was fried.
07-08-2014, 10:25 PM
Utility company where I live run close to 125v as possible and yes it does vary with line loading especially at peak times. Also low batteries in voltmeter can give you wild readings, might want to check that.
doodler
07-12-2014, 09:37 AM
Hmmmmm. Low batteries, that could be the problem. I know that thing had died a few times but seems to come back to life later. I don't think the battery is supposed to be a serviceable part, but of course I've opened it and I think it's just a AA battery
2020 Cherokee 294BH
07-12-2014, 09:58 AM
In most meters, the battery is only for reading resistance. When reading amps/volts, the current to move the meter needle comes from what you're reading. (Qualifier - This may only apply to analog meters. I'm not too familiar with the guts of a digital meter.)
2011 Traverse LT, 3.6L, FWD
07-12-2014, 12:28 PM
So now that's interesting. I was hoping you were right but not expecting it. With a digital volt meter, make sure you have a good battery. I took out the 9v battery out of my digital voltmeter and found that it was jut about dead. Alive enough I guess to give me a zero reading before plugging into a wall jack but dead enough to sque the readings. So just now, I plug into the wall and I am getting a 124. I plug in the new battery and I'm getting a 118...... Just to make sure I do it again with the old battery an same readings. I try another plug and do the same thing. I'm getting a 6v difference in my readings. I keep the new battery and keep an eye on my "true" readings throughout the week and see what I'm getting. Thanks for all ya'lls input.
Take The Road Less Traveled!
2020 Cherokee 294BH
07-13-2014, 04:29 PM
the digital voltmeters will give you wild readings with low battery no matter if your trying to read volts, amps or resistance/ohms.
doodler
07-13-2014, 04:50 PM
I may getting very technical here but the transformer on the pole outside of your house is not a tap changer one. The taps on those transformers are fixed. What does have taps is a voltage regulator.
Usually there is a piece of equipment called a voltage regulator somewhere on the line. This could be installed out on the line a distance from the substation, in the substation itself or the large power transformer in the substation may have a tap changer integral to it.
The voltage regulator is typically used to maintain voltage regulation on the line by either boosting or bucking the voltage by moving taps. It is set up by the utility to maintain voltage within limits at the farthest service point from that voltage regulator. Very long distribution lines may have several voltage regulators on the line. These do fail and the voltage may not regulate.
The electric power system is dynamic in that the voltage does fluctuate depending on many factors. The prevalent one is the loading on the line. If there is a large single load on the line, say a commercial/industrial facility, and something happens where the entire facility trips off line, the voltage will go high for a short period of time until voltage regulation can react and bring voltage back to normal. The reverse is true also.
07-13-2014, 09:10 PM
Some transformers do have tap changers. Most of the time they are used for special situations. Not all that common on basic residential homes.
doodler
