Old 10-03-2015, 10:20 PM   #1
Wingdreamer's Avatar
Want to upgrade ceiling speakers...
I have 4 of the incredibly crappy, white wedge shaped speakers mounted to the ceiling of my new trailer. I have upgraded the stereo and now want to upgrade the speakers. I have no problem cutting holes in the ceiling to install new 5.5" or 6.5" coax speakers. Question is, how much clearance do I have between the inner and outer ceilings? Anyone done this mod?
You can see 2 of the 4 crappy units mounted to the ceiling in the attached pic....
2015 Forest River Vibe 268RKS being pulled by a 2010 F150 Lariat 5.4l, 3.73 axle Super Cab, Max Tow with 11,300 lb tow capacity , Equalizer 4 point W/D hitch
Wingdreamer is offline   Reply With Quote
Old 10-04-2015, 10:27 AM   #2
hammer55's Avatar
pull one out an measure the distance
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
hammer55 is offline   Reply With Quote
Old 10-05-2015, 02:11 PM   #3
About two inches, i installed 40$ 3 way Kenwood s made a world of difference. Dont expect too much bass though.
Kuba is offline   Reply With Quote
Old 10-05-2015, 02:12 PM   #4
Btw they were 6 3/4
Old 10-05-2015, 07:54 PM   #5
What type of trailer do you have? Just curious about fit...
Old 10-05-2015, 08:02 PM   #6
davel1971's Avatar
best to take one out and measure to be safe. You could have had one out faster than you posted the question
David & Lynn
Old 10-05-2015, 08:06 PM   #7
phat phrog stunt crew
Bose surround sound. They still surface mount but will beat just about anything out there.
Sent from ny nook using fairly accurate digits.
dwaynerz is offline   Reply With Quote
Old 10-05-2015, 08:08 PM   #8
davel1971's Avatar
probably not room for them. Slide will knock them off. Not much clearance between slide top and ceiling
David & Lynn
Old 10-06-2015, 09:40 AM   #9
Already dropped a speaker down. These are surface mount, so no hole in ceiling except tiny one where speaker goes through. Even if I stuck a think screwdriver into the wire hole to determine depth, I would have no idea if there is a roof bow/support nearby the would not allow mounting of a regular speaker flush mount.
Old 10-06-2015, 09:56 AM   #10
Put covers, re-fish wire, mount speakers elsewhere?
upgrade
