Do you get hot water if using just propane. If so then your bypass valves are probably set correct. If not, then you need to look there first.
Is you circuit breaker to the water heater on. Some people flip them off, and forget about them.
Are you on shore power or generator? You have to have 120 volt AC for the electric heating element to work.
Is there any possibility you may have turned on the element without water in the tank. If so you may have burned out the electric element
2011 Flagstaff 831 RLBSS
