Old 02-29-2012, 09:04 PM   #1
Adony's Avatar
Weatherproof 12v outlet??
I have a new Winegard satellite antenna that requires a 12vdc power source to operate. I have found a place to tap the 12vdc inside the TT but am looking for a suitable outlet (weatherproof) that can be installed next to the SAT in jack on the outside skin of the trailer. Anyone have any ideas or suggestions?
Adony is offline   Reply With Quote
Old 02-29-2012, 09:17 PM   #2
Fire Instructor's Avatar
West Marine has WEST MARINE 12V Flush-Mount Receptacles & Plugs at West Marine and a few others available.
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 02-29-2012, 09:20 PM   #3
sherdep's Avatar
My suggestion would be to look at the Marine Store's or any Marine Parts house.
I would do the Cigarette style so you can unhook the Sat and leave the Plug on the side of the camper.
12V Waterproof 16A Panel Mounted Din Socket + Cap
the 1st pic looks like it would be a nice fit since it has a screwed on cover instead of a pressed fit
the 2nd pic is made by Marinco and its called a Seallink - it has a rubber cover which over time becomes loose and eventually breaks off so I do not recommend that for your application
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
12 Volt
