Originally Posted by DavidBo
I have similar plans. I intend to tap into the wires going the 12V charging panel which will be close to where I'm putting the booster transmitter. That way if something goes wonky I won't be blowing any essential fuses.
If you’ve got a central vacuum, it usually is, well in the center of the RV. This would be the best spot to get good coverage from front to back. Here’s where the vacuum comes in, they’ve put a plug in the inside of the wall, mine is behind the fuse box where there is a nice little cavity where all their wires ran. Kinda the command location where it all comes into the inside. The plug is a regular house outlet back there. That’s where I plugged mine into. It’s hidden and out of the way and all you see is an antenna mounted on the side of the wall.
