Westinghouse 4500 Duel Fuel Question
Helping a friend getting his Westinghouse 4500 Duel fuel running off the RV propane low pressure line. Has anyone done this? Is there usually enough flow through a low pressure port. Generator works fine hooked up to a 20# tank with the generators supplied regulator.
Just to be clear, when hooked up to the low pressure port on the RV, not using the pressure regulator that comes with the generator.
I may need to get out my manometer. I know it needs between 7" and 14" of WC.
