Old 03-16-2014, 09:07 AM   #11
Thank you guys ,,, you are a wealth of info... so should I just head down with the new converter and hope for the best??? what about hotwater heater and components hot water heater lighted switch is with the water pump switch..I will order the new converter today and head down on Saturday to throw the dice lol...there is plenty of room where this converter mouds it under the closet .. wow room huh!!! thanx= again!!!!
waspkfd is offline   Reply With Quote
Old 03-16-2014, 10:24 AM   #12
TURBS's Avatar
Originally Posted by gljurczyk View Post
That's okay we are not that stuck-up. But I would get a progressive 55 amp to replace it. Your 12v stuff should be okay just the 110v on or not can still be fried. ......
I agree.
As long as your shopping for a converter go with a progressive dynamics brand converter.
I'd personally go with a 70 amp but a 55 amp will be fine.
Hang around the forum as you may be able to help us no matter what brand you have.
If your handy then you don't need to replace your whole distribution center you can just install the pd converter inside your wfco case.
It's very time consuming to replace the whole unit when you don't need to.
TURBS
Sabre owners united!
Old 03-16-2014, 11:46 AM   #13
Witch Doctor's Avatar
Originally Posted by f1100turbo View Post
I agree.
TURBS
Ya but Turbs he won't get to use the advantage of the wizard without doing the board to...
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 03-16-2014, 12:11 PM   #14
TURBS's Avatar
Oh not true my friend.
This is what he needs right here.
http://www.boatandrvaccessories.com/...ducts&kw=bb075
TURBS
Old 03-16-2014, 01:36 PM   #15
PROGRESSIVE DYNAMICS PD9260C 60 AMP RV CONVERTER CHARGER WITH REMOTE PENDANT AND SMART CHARGING
TURBS
Okay that will work, I was thinking on the replacement terms of the slide in replacement for WFCO. and just adding the convertor and not replacing the board like I had to.......
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-17-2014, 05:52 AM   #16
which should I go with then?? that will just bolt in,,,I don't want to do any funky rewireing,, I hate electric lol,,,,, Thanx again!!!
Old 03-17-2014, 06:29 AM   #17
TURBS's Avatar
Get this series then.
http://www.progressivedyn.com/pd4600...placement.html
Direct replacement.
TURBS
converter, wfco
