Old 06-30-2016, 06:16 PM   #11
Originally Posted by Iwannacamp View Post
Hmm. Correct. 15 amp circuit will not carry 2 1500 watt load. OHMs law prohibits that. If this is permanent and you are paying the electric...I would seek a more efficient heat source...10 amps x # of heaters... You can heat for less.
we have a more efficient heat source...i just didn't bring it up because it had nothing to do with the electrical question...there's a vent-less propane heater
the new 20 amp circuit not being used by the water heater can be used, if necessary for a space heater without the worry of kicking a breaker
esty is offline   Reply With Quote
Old 06-30-2016, 08:01 PM   #12
sub panel
Check to see if the rv panel has a bonded neutral bar.
markb422 is offline   Reply With Quote
Old 06-30-2016, 08:13 PM   #13
i know the neutral bar and ground bar are not connected, they are separate...i believe that's what's meant by bonded, where the 2 are connected, they are not
how would a bonded neutral or not effect the auto operation of the t-stat ?
Old 06-30-2016, 08:36 PM   #14
Originally Posted by esty View Post
i believe with 60 amps we can wire a 30 amp plug or hard wire it in the sub-panel for the existing WFCO panel and the remaining 30 amps for the 2 new circuits
ideally we should have at least 70 amps but since we already have the #6 wire and 60 amp breaker, we'll live with the possibility of flipping a breaker
what do you guys think about the plan ?
You should be ok on total load. It is rare that everything is turned on at the same time.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
cat, wfco, modifications
