Old 10-11-2012, 11:48 AM   #1
WFCO WF 8845 Blows fuses (intermittenly)
I have a WFCO WF 8845 converter in a Fleetwood Terry Quantum 5th wheeler that blows the 2 reverse battery protection fuses once in awhile,twice now in 4-5 weeks .The 2 batterys have not been tampered with to cause them to blow. Replace the fuses and the unit works on til the next time they blow. Can't say for sure but it seemed to happen when the furnace was runningwhy? What else could cause these fuses to blow?? Idea's anybody?
Outlandermax is offline   Reply With Quote
Old 10-11-2012, 11:50 AM   #2
TURBS's Avatar
Those will normally only blow when battery cables are reversed.
Unless you have an issue with the converter.
How old are the batteries ? And what condition are they in ?
Turbs
Old 10-11-2012, 11:55 AM   #3
Batterys are 2 years old but check good, load tested and hydrodmeter tested
Old 10-11-2012, 11:58 AM   #4
TURBS's Avatar
Try disconnecting the batteries then see if fuses blow when furnace is running and hooked to shore power.
Old 10-11-2012, 06:30 PM   #5
Thanks f1100turbo
Sucker is gone! Disconnected batterys and discovered no DC volts on converter output. Drilled out cover rivets and discovered blown 15 amp internal fuse, replaced fuse and as soon as i pluged the converter in the fuse blew right away.I guess it was on the way out and today was the day. Now i am in the market for a new converter ,one in which i can turn on the radio and listen to it as the WFCO always caused radio interference staticwhen hooked to shore line or genset. Any and all recomendations at a reasonable price will be taken into consideration.Thanks.
Old 10-11-2012, 07:31 PM   #6
TURBS's Avatar
Originally Posted by Outlandermax
Thanks f1100turbo
Progressive dynamics inteli power converter imo.
Wfco converters are less then desirable.
Get a pd 50 or 60 amp.
http://www.progressivedyn.com/rv_products.html
Turbs
Old 10-12-2012, 07:38 AM   #7
TURBS's Avatar
keep us updated to your issue .
Old 10-12-2012, 08:31 AM   #8
Yes, i was looking at the 9260c , hopefully a good choice ,trailer is going in storage tomorrow(getting too cold here in NL. now) so i will have to order a converter over the winter. Thanks Turbs.
Later
Doug
