Old 04-03-2016, 11:45 AM   #1
chideock's Avatar
WFCO WF-8930 Distribution Center CB
Does anyone know what AC circuit breakers are in this panel? I have one in my hand it does not have labels as to what make it is.
I want to get another 15 amp breaker.
Tom
2016 Sunseeker 3010ds towing a 2013 Ford Explorer 3.5L AWD.
chideock is offline   Reply With Quote
Old 04-03-2016, 06:49 PM   #2
Pathfinder75's Avatar
WFCO web site has a pdf manual on that unit See Attached PDF
Model WF-8930/50 30amp and 50 amp models
UL Listed Branch Circuit Breakers, rated for 120/240 Vac, maximum 20 Aac
Acceptable circuit breakers are as follows:
Cutler Hammer ........ Type Bd2020, A2020
ITE/Siemens ............ Type QP or QT
Square D ................. Type HOMT
The PDF shows 3 brands of breakers for main and Branch circuits.
Good luck. These should be easy to find.
2017 Montana HC 353RL
2017 Ford F350 6.7L Dsl., CC, SWR, LB, B&W Companion #BWRVK3300 OEM Prep mtg.
Traded- 2012 Coachman Leprechaun 319DSF
retired-Towed -2011 Chevrolet Equinox 4-cyl. AWD
Pathfinder75 is offline   Reply With Quote
Old 04-03-2016, 09:23 PM   #3
chideock's Avatar
Pathfinder75
Thank you very much. I had not found that manual. I had one that did not include the page on CBs. I looked at my CB and it has HOMT on it. Must be a SquareD then.
Thanks again
Tom
Old 04-04-2016, 07:23 AM   #4
Head Rambler
Most of the standard plug-in tandem (or even single) circuit breakers you find at home improvement stores will fit the panel. They list a few to give you a choice, but they're all built to the same standard.
Gotta go campin!
Old 04-04-2016, 03:15 PM   #5
chideock's Avatar
Bama
Thanks. Got a new CB works good.
wfco
