Old 11-16-2015, 02:02 PM   #1
jaxfl's Avatar
What a PITA this has turned into...or
If it was not for bad luck I would not have any
Here is the story in a short form.
#1-On Wednesday I tried to start the Generator on the 2008 Sunseeker and only got a clicking. Darn. Took the house battery to the shop and it had a bad cell. Bought a new battery and hooked it up. Pushed the generator button and nothing happened. So went and checked the battery... hooked it up backward... . Switch it and pushed the generator button... nothing again. Opened the generator cabinet and checked the fuse, popped. Replaced and pushed the button, popped again. Well I will work on it later, going to the campground don't need it this weekend...I have shore power.
#2-At the campground all is good, turned on the AC and could feel it vibrate, but not blowing any air. Well ok, it is not hot this weekend...turned it off.
#3-During the night the refer stopped working... little check light was on. Went outside checked the battery and it was at 12.58v, checked the shore power all is working...put the battery charger on to help... Next morning the battery was at 13.7v and the refer was working,, checked the converter and yes both fuses were blown. Replaced them. Still no AC or Generator
So the Generator still keeps blowing a fuse each time I try, the AC still will not blow any air, the converter seems to be ok now and charges the battery with the new fuses.. So what do I do. Take it in to a repair shop and use the GS Extended warranty and let them try to fix it or is there more fuses that are in the AC and what about the generator?
jaxfl is offline   Reply With Quote
Old 11-17-2015, 12:27 AM   #2
Sounds like possible logic boards got burnt with the reverse hookup.
Are the battery/batteries definitely hooked up properly?
Can you isolate the problem units?
A/C: could be a start/run capacitor for the fan circuit.
The generator: you should have two locations to start it. Does it blow fuses using either location?
Good Luck with the fix.
mfMcFroggierPod is offline   Reply With Quote
Old 11-17-2015, 06:40 AM   #3
jaxfl's Avatar
Are the battery/batteries definitely hooked up properly?.... Yes and they are charging
Can you isolate the problem units?... no
Does it blow fuses using either location?...Yes
A/C: could be a start/run capacitor for the fan circuit....where would that be located?
Sounds like possible logic boards got burnt.... where is that located?
Old 11-17-2015, 06:57 AM   #4
B and B's Avatar
Well I would take it in for Warranty but don't tell them you hooked up the battery backwards and hope they don't read this forum!
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 11-17-2015, 07:07 AM   #5
Kenny kustom's Avatar
X2.
But it is your fault...
2015 RAM 3500 CCSB CUMMINS
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 11-17-2015, 07:38 AM   #6
HONDAMAN174's Avatar
Just a thought: if you can, see if you can turn the crank on the generator with a ratchet or wrench one way or the other. I have seen my buddy's Oman starter get hung up on the flywheel and blow fuses when try to start.
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 11-17-2015, 12:22 PM   #7
SlowrideHD's Avatar
If you go ahead and be honest with the repair people, they will likely find the trouble faster. And a good repairman is going to know what happened anyway.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
SlowrideHD is offline   Reply With Quote
Old 11-17-2015, 03:00 PM   #8
2007 WildCat 32QBBS
05CrewDually's Avatar
Originally Posted by Kenny kustom View Post
X2.
2016 Sabre 36QBOK
Warranty on an 08?
Anyways, once you get to that point where you're out of options and you take it to a shop, be honest and tell the guy you hooked it up backwards. It may save you hours of shop rate dianostics which could be +/-100 bucks an hour.
05CrewDually is offline   Reply With Quote
Old 11-17-2015, 03:10 PM   #9
OscarsMom2's Avatar
AC Not Working
We had problems with one of our Cougar fifth wheels when the AC didn't work. Took it to the dealer and they said there were sticks in the unit. The next summer we had the same thing happen. No AC only a humming noise. I got on top of the coach and removed the shroud and lubed the fan so it turned freely. For some reason it was stuck. I had to do this every year with that coach.
2017 Wildcat Maxx 26BHS
2016 Rockwood MiniLite 2503S (2015-2016)
2012 Ford F-150 Eco-Boost
OscarsMom2 is online now   Reply With Quote
Old 11-17-2015, 06:58 PM   #10
Originally Posted by 05CrewDually View Post
Warranty on an 08?
Wise words.
They will know what happened eventually. Save them the time and you the money.
2016 Sabre 36QBOK
