Old 04-18-2015, 02:53 PM   #1
Bianchina3's Avatar
What do you do with your batteries?
I am setting up my TT with a second battery. I will hook it up to the original and therein lies to lies the problem/question. If I hook them together I will have to completely disassemble the setup to take them to my house between trips. This seems like a hassle. We have the TT stored someplace that doesn't have electricity available and I want to make sure that they are charged before the trip.
What do others do?
Ed and Jennifer Bianchina
2014 Dodge Ram 1500 Crew Cab
2011 Puma 2011 26 RLSS
Bianchina3 is offline   Reply With Quote
Old 04-18-2015, 02:57 PM   #2
Without lugging them back and forth, about the only other options are to put them on solar while in storage or run out the day before and run your generator to get them topped off.
Is there a reason why you can't just park it overnight at your home before departure and plug in to your home electric? You probably want to be doing that anyway to get your reefer cooled down for the trip.
rana is offline   Reply With Quote
Old 04-18-2015, 06:56 PM   #3
Bianchina3's Avatar
I've thought of that but it is about 1/2 hour away from the house. Is overnight enough time to charge both batteries?
Also when I plug into the car does the car charge the batteries. When I plug into shore power does that charge the batteries?
Old 04-18-2015, 07:02 PM   #4
Ford Idaho's Avatar
Depends on the condition of the batteries.
Yes.
Yes.
Old 04-18-2015, 07:06 PM   #5
wbdavey's Avatar
Overnight should be enough to charge your batteries assuming the batteries are not completely flat due to some load that remained powered up while in storage. Common loads such as CO detectors, smoke alarms, digital radios can drain your batteries while in storage.
The answers to your questions: yes, the batteries charge from the tow vehicle and yes, the batteries charge when powered from shore power.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
wbdavey is offline   Reply With Quote
Old 04-18-2015, 07:29 PM   #6
fonzie's Avatar
Add a battery disconnect next to batteries......
Here is one example how to do it....
http://www.forestriverforums.com/for...ood-74256.html
Name:	battery disconect.jpg
Fonzie
Old 04-18-2015, 07:53 PM   #7
On our travel trailer, the two batteries sitting on the tongue were easily accessible (which eased battery maintenance). So, if our travel trailer was going to sit for only a few weeks to a month before being used again, I left them on the trailer at our storage lot. But, if it was going to sit for several months, I took them out, put them in my garage, and connected them to $4.99 float chargers from Harbor Freight. Those inexpensive, 12v deep-cycle marine batteries were used for 3 years and were still providing full power when we sold that trailer (and batteries) last month.
With our new 5th wheel, the battery is inside a basement storage compartment and, in turn, inside a vented battery box, which complicates maintenance and removal. So, I am replacing the dealer-installed 12v battery with two 6v golf cart batteries and installing a solar panel and controller. The controller will provide float and equalization charging stages when the trailer is parked, but will also provide the bulk and absorption stages needed when the trailer/batteries are in use.
If yo have generator, a third option would be to take it to your storage yard and use it to charge the batteries on an as-needed basis.
"Retirement is the best job I ever had!"
2020 Winnebago Navion 24V Sprinter Class C
Sold in 2021: 2016 Rockwood Signature Ultra Lite 8244WS 5th Wheel
Sold in 2014: 2012 Rockwood Mini Lite 2109S
fanrgs is offline   Reply With Quote
Old 04-18-2015, 08:47 PM   #8
Bianchina3's Avatar
Great info!
Awesome responses everyone.
I already plan on add in a cut off switch to the battery box. I didn't realize they could sit for weeks without needing to charge. I am not too concerned with the total charge of the batteries since when we need them we will be on the road for a few hours before we get to the camp site.
Old 04-18-2015, 09:17 PM   #9
If you are going to let the batteries sit on the trailer for up to a month before the next use, make sure they are fully charged before taking the trailer to the storage yard. Check the voltage and/or, better yet, the battery specific gravity with a hydrometer to make sure they are charged up.
One reason I brought my batteries home for long periods was winter weather. Batteries don't like cold and, if not fully charged, can actually freeze. So, if you are in a cold location, you may want to consider sheltering them in a heated location and keeping them fully charged all winter.
Old 04-19-2015, 06:21 AM   #10
bikendan's Avatar
We have a cut off switch and our batteries are still nearly fully charged even after 4 months of storage.
Old 04-19-2015, 09:43 AM   #11
ColoradoRick's Avatar
Yes, charged batteries will stay charged for quite a while..a month or more. (If they are healthy batteries.) We always plug the trailer into the 110-outlet at the house as soon as we pull up (to load or unload or wash, etc.) and that's the last thing we disconnect before pulling out.
My old camper didn't have a cut-off switch so I would just disconnect the negative (black) terminal from the battery. (It had a wing-nut for this.)
I've heard that we're not supposed to leave the trailer plugged into the truck when parked for long periods because the trailer will draw from the truck batteries. (Not sure that's true but I don't take any chances.)
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 04-19-2015, 06:50 PM   #12
Our 2012 FR travel trailer had a factory battery cut-off switch. It was a chrome plated push-pull switch next to the circuit breaker/fuse panel inside the main living area. It was very convenient for shutting all battery power off when we went hiking, kayaking, or sightseeing. Our 5th wheel's cut-off switch is located in the basement compartment containing the battery and is not nearly as convenient for quickly shutting everything down. So, you might check your trailer for a similar switch before installing a new one.
Old 04-19-2015, 11:33 PM   #13
Originally Posted by fanrgs View Post
Our ... battery cut-off switch ... was very convenient for shutting all battery power off when we went hiking, kayaking, or sightseeing.
Doesn't that kill the refrigerator, too?
Sent from my phone using Tapatalk.
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, TBD (Est: 80+)
chriscowles is offline   Reply With Quote
Old 04-20-2015, 09:29 AM   #14
AKA: 'tiredTeacher
awellis3's Avatar
Yes, it does.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 04-20-2015, 10:50 AM   #15
Yes, but we have a sending unit for a wireless indoor-outdoor thermometer in our refrigerator. So we can read the frig temp without opening the door. If the temp inside is 40 degrees or lower, it has been able to maintain it while we are gone. Of course, we have never gone hiking in Death Valley in mid-summer with the switch shut off either. But, if we had, we probably would have had bigger problems than the frig temp to worry about!
That's an unlikely extreme, I'll admit, but we have towed with the gas and battery off on summer days without any problems as long as we don't open the frig door while in transit. And, for safety reasons, we don't travel with the gas on--which, if I remember right from our Alaska trip, is actually illegal in Canada.
Old 04-20-2015, 11:33 AM   #16
Wow, no wonder people buy generators....I went to the trailer yesterday to work on my plumbing and it was in the 30's....felt even colder inside the camper!
So I turned on the battery and plugged in the little space heater...NOTHING....gesh, the batteries can't even run that thing?
Rick & Karen
Monument, Colorado
Old 04-20-2015, 11:41 AM   #17
KyDan's Avatar
Space heater = 120v ac. Battery = 12 v dc. Two different systems. You should have been able to use your LP furnace for a few hours.
Peace!
Dan & Rita D
Old 04-20-2015, 11:45 AM   #18
TURBS's Avatar
This should help for amp draws.
http://www.forestriverforums.com/for...aws-17300.html
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-20-2015, 12:05 PM   #19
bikendan's Avatar
Suggest you read up on "the 12 volt Side of Life" website.
Your battery won't run 110vAC items like a space heater.
Nor will the outlets work on battery power.
battery
