Old 07-23-2017, 07:26 PM   #1
Canadian Member
What Has Your PI EMS Protected You From?
A lot of FRF members have a Progressive Industries EMS. I installed a hard wired EMS in my previous Roo and put one in my current TT, too. I've mostly seen low voltage but once saw high voltage and a neighbor had a "hot skin" condition.
What has your PI EMS protected you from?
2019 Rockwood Signature 8290BS
Old 07-23-2017, 08:05 PM   #2
mblee21's Avatar
It protected me from an open ground ( E-2) just this weekend. I have used it 4 times camping since I have had it and this weekend was the first time it threw a code. Park Ranger came around with his multi meter and said he couldn't see anything wrong with it. I asked him to send maintenance to check it too. They came and the breaker was so hot they couldn't hardly touch it. They replaced the 30 amp breaker and had a great weekend camping.
mblee21 is offline   Reply With Quote
Old 07-23-2017, 08:25 PM   #3
Mr. Dan's Avatar
HIGH voltage - as much as 138v! Campground called electricians who didn't know DW was watching out the trailer window. They came, looked, left but tested nothing. I told camp management they were wasting their money since the electricians did nothing. They returned within an hour!
Our EMS shut off our power probably 30 times in 16 hours before we were sent home because of rising lake water which threatened to block the only road out AND was rising INTO A BIG POWER CENTER in the park!
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 0; booked = 14
Old 07-23-2017, 11:46 PM   #4
banda's Avatar
Loose breaker connection once, and reverse polarity twice. The last time it took me an hour to convince park personnel to correct the problem.
banda is offline   Reply With Quote
Old 07-24-2017, 12:23 AM   #5
Briorick's Avatar
We have experienced 3 incidents. Thank goodness for our EMS Surge Protector.
The 1st time showed Reverse Polarity. 2nd time was a total Blackout in the CG from a passing Tornado, and the 3rd we encountered a Power Surge during the night. Very glad we purchased it. Better to have it and not need it, than to need it and not have it. JMO!
Rick & Brian
1 Happy Camper Pup ( Mya )
2017 Salem Cruise Lite 232RBXL
2004 GMC Sierra 2500HD LT 4x4 6.0 / 4:10
The best plans can be of those that happen in the spur of the moment!
Briorick is offline   Reply With Quote
Old 07-24-2017, 12:52 AM   #6
Hutch333id's Avatar
We have just returned from a 4 1/2 week road trip across Canada and then back through the US. Our hardwired PI EMS discovered an open ground at one site which, when I reported it to the owner, he asked me what that meant. Not being electrically experienced, I had to Google it and then told him. The fault was repaired within a day to two.
At another CG we experienced repeated low voltage problems and then finally, on our way home it twice saved us at separate CG's when a lightening storm hit the CG power and kicked that out.
I don't know for sure what this saved us from on all of these occasions but I do know that all the electrical appliances still work in the RV and for that I am happy to have invested the money making this purchase.
Richard & Diane
2014 Cedar Creek 38FL
2016 F350 Lariat CC DRW
Retired Metropolitan Police (UK)
Hutch333id is offline   Reply With Quote
Old 07-24-2017, 01:04 AM   #7
SYE
SYE's Avatar
Low voltage at a CG 3 different times, No ground in the plug 1 time.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 47 reserved
SYE is offline   Reply With Quote
Old 07-24-2017, 02:33 PM   #8
EMS and Furrion
This spring we experienced periodic power losses over a 2 day period as our Progressive 50 amp EMS occasionally cut power to our Cardinal 3850. We finally lost all power on the second day. I assumed our Progressive EMS went bad: WRONG!!! The technician at Progressive walked me through the troubleshooting and we were able to confirm that the Furrion F50-ATS (automatic transfer switch) was the problem. I had clean power coming into the Furrion ATS and bad power leaving the Furrion ATS. The Progressive EMS did its job: it saved our coach and the electrical system!
To quickly restore power, I bypassed the Furrion ATS by splicing the in-coming and out-going 6 gauge cables. The temporary splice restored power to the Progressive EMS and our Cardinal. A few thoughts in closing:
1. The in-line Progressive EMS should be installed after the ATS to protect against ATS failure;
2. A portable EMS would not have protected us against the ATS failure.
CT3850 is offline   Reply With Quote
Old 07-24-2017, 02:36 PM   #9
millman75's Avatar
Low voltage on line 1 was the error, but voltage was dropping to 103 on line 1 and 105 on line 2. Ranger was mad because the camp had just replaced the power lines. They called the electrician and he admitted that all 30 amp outlets were wired to line 1. Turns out that most of the campers near us were using 30 amps which was sucking down L1 voltage on a 93 degree, 85% humidity sunny day! Electrician stated they would re-wire that line later
millman75 is offline   Reply With Quote
Old 07-24-2017, 02:50 PM   #10
MilCop4523's Avatar
in 2011 when everyone told me I didn't need an EMS system. they when I asked the questions.
2 weeks into ownership 11 trailers fried when an aluminum ground cable rotted off a main power line in a KOA campground blowing microwaves up, causing inverters to pop.
2 of the 11 got compensation from the campground 4 months later.
it ended our 1st camping season.
Since then we've hardwired a PI EMS 30 amp system into 4 trailers. we did ours with 30amp twist locks so they could be removed prior to sale or trade in.
Current Toy hauler on the 16 Ecoboost was 2 days in our possession and had the PI EMS30 wired in.
a lot of people who said they would never need one looked at the pics of the damage to my 2012 Salem and decided they would not take the chance.
nothing promotes the sale of an item for safety than seeing someone with damaged products.
Name:	truck and trailer.jpg
ID:	145916   Click image for larger version
ID:	145917   Click image for larger version
ID:	145918   Click image for larger version
Name:	16 and 18.jpg
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
MilCop4523 is offline   Reply With Quote
