Old 10-01-2016, 10:23 PM   #11
2012 Solera
Formerly in the LED industry, I consider Philips Lumileds Luxeon, Cree and Nichia the "top tier". Osram is pretty close.
JLeising
2012 Solera "S"
Calif SF Bay Area
JLeising is online now   Reply With Quote
Old 10-01-2016, 11:19 PM   #12
Lost in time
Originally Posted by Radio View Post
They do 12 volt stuff?
Absolutely...
www.superbrightleds.com
Go to the RV section and type in CREE in the search box....
SidecarFlip is offline   Reply With Quote
Old 10-11-2016, 08:18 PM   #13
Cyber Phrenologist
Radio's Avatar
Parting shot - RFI testing the LEDs
Had some time this afternoon so more out of curiosity than concern I went out to the trailer to do some RFI testing of all the LEDs I have recently installed.
Starting with all the LEDs off I monitored the VHF/UHF amateur bands with the Kenwood V7A that lives in the trailer permanently. I opened the squelch on both bands and turned on all the LEDs. I did not notice a perceptible rise in background noise. A local repeater gave its voice ID and sounded just fine.
So I moved on to the Concertone AM/FM/WX radio.
I started the test of each band with all LEDs off and then turned them all on. Again, no rise in noise. I listened to weak stations and empty channels. No appreciable noise that I thought I could blame on the LEDs.
And then finally the off-air TV. No problems. Even with all 10 remaining $1.50 Chinese E-bay LEDs lit, no detectable RFI.
I didn't test amateur HF radio as it was just too much trouble to drag the TS-570 out to the trailer and set all that up. Maybe next time we go camping. But I don't think there will be an issue.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 10-11-2016, 08:59 PM   #14
Have converted 3 campers in past 4 years to 100% LED lighting.
Have nothing but good things to say about the cheap 48smd LED panel lights that I got from Ebay. 10x 48 SMD Warm White Light Panel T10 BA9S Festoon Dome LED Interior Bulb Lamp | eBay
I have them in all of my overhead lighting and have never had a failure yet except for occasional release of double sided tape which I remedied with a hot glue gun to secure the lights.
For lights over reading areas, couches, and tables, I used cheap ebay wedge base bulbs which also have been great. I prefer a more white/bluish lower intensity light over reading areas and the dinette table 20x Warm White T10 921 194 RV Trailer 42 SMD 12V Backup Reverse LED Lights Bulbs | eBay
You can spend 8-16 dollars a bulb but I won't. I'll save top tier for the liquor I drink and not my interior lights. As cheap as those Ebay lights are, replacements are cheap if needed but I have yet need to replace one.
Skyliner is offline   Reply With Quote
led, light
