What is involved in moving this electrical component off the floor of my Leprachaun?
Not sure if this belongs here or in the Motorhomes section, but I assume someone will move it if it does not belong here.
Removed the dinette from our 2018 Leprechaun 210RS with the idea of putting in something that you could actually sit in for an evening without feeling like you'd been tortured on the rack for a week. Found this under the seating. I assume it runs from the generator to somewhere and I can't imagine why it needed to be put on the floor of the RV about 16 inches from the wall.
Questions:
1. Exactly what the heck is it and what purpose does it serve except to get in the way of whatever else I may want to do with the space?
2. Can it be moved to someplace that actually makes sense, perhaps either right against the wall or, better yet, under the floor?
3. What is involved to moving it? Is it something an amateur electrician wants to take on or should I find someone to do it, and if find someone, should I find an RV repair person or will a good household electrician do?
4. What is the gunk they used to seal the openings? I assume just a clear silicon caulk, but does anyone actually know?
Thanks in advance for any help.
2018 Coachmen Leprachaun 210RS with DW, Nanuq the Samoyd puppy and the cat.
