Old 08-28-2016, 09:23 AM   #1
gectisme's Avatar
What is this filter and fuse for?
So, the microwave was pushed way back in when we arrived at our current camp site. I pulled it out to see what happened and this Filter and Fuse Holder was under the wood plate that the microwave sits on. What is it for? I am guessing the Stove Vent fan/light since it's right above it, but can't follow the wires and wondering why it would be in place you would never look for a fuse... I pulled the wood plate up because it was not sitting flat and this Filter and Fuse Holder was the reason why.
ID:	118602   Click image for larger version
2016 Windjammer 3006WK
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, (not really used, left over from our truck camper). Equalizer E4 1.4k/14k WD Hitch. TST 507 TPMS. Furrion FOS48TA Observation Camera. Garmin RV-760 GPS. Honda 2000i Genny, PI EMS-PT30C.
gectisme is online now   Reply With Quote
Old 08-28-2016, 09:30 AM   #2
northstar1960's Avatar
it was put there to drive you and any techs nuts trying to find why your lights aren't working .
northstar1960 is offline   Reply With Quote
Old 08-28-2016, 03:54 PM   #3
gectisme's Avatar
Northstar, thanks for the reply, to clarify, are you saying this is for the interior lights, i.e., the room lights on the ceiling? Or are you saying they are for the out side lights, i.e., the porch light, stair lights, etc? Or are you saying it is for the driving lights on the outside of the trailer?
Old 08-28-2016, 04:18 PM   #4
Does it actually have a fuse in it?
2014 Blue Ridge 3715BH <- Read the saga
2013 Sierra 3500HD Denali CCLB DRW 4x4 Duramax w/ Reese 20K
Camped: 2016=6, 2015=9, 2014=27
USN Retired (26 years), but not Retired retired
Home Port Orlando
Narboza is offline   Reply With Quote
Old 08-29-2016, 09:44 AM   #5
That you will need to figure out for yourself . turn everything on the pull the fuse and see what goes out
Old 08-29-2016, 12:28 PM   #6
It may be a filter/fuse for the radio. That's the only item I could imagine requiring a noise filter.
Matt.S is offline   Reply With Quote
Old 08-30-2016, 08:51 AM   #7
Wolverine 1945's Avatar
That is what I was thinking Radio or TV ???
Is there a number on the filter,,, you could maybe Google it ???
Wolverine 1945 is offline   Reply With Quote
Old 08-30-2016, 08:54 AM   #8
Microwave Noise Filter !!!
Old 08-30-2016, 09:26 AM   #9
tahoe1840's Avatar
Recently our range hood fan went out and while repairing it I came across the exact same filter/fuse, I opened the black box and it does not appear to be a fuse although the case says "Fuse" on it. It appears to be copper wire wrapped around a round magnet or metallic object. It is connected to the range fan on the hot side and appears to have something to do with it. It is also definitely low voltage and not connected in anyway to the microwave.
Side note, the range fan has a fuse taped on the side of the 12 volt motor as well and that was what my problem was.
Hope any of this helps.
tahoe1840 is offline   Reply With Quote
Old 08-30-2016, 12:57 PM   #10
gectisme's Avatar
Thanks tahoe1840,
Before I read this, I opened it too. You are right it is just a filter, no fuse, and it is on the 12vdc line. Good info on the fuse next to the fan motor too!
fuse
