Old 09-09-2016, 03:21 PM   #11
Originally Posted by goots View Post
Get a Honda 3000 watts gen. the Champion is to loud and cheap
no thank you,.....that Champion 3400w is rated at 59 dB by the company, the same as the Honda 2000w, ....... can you say that about your Honda 3000???.... so I guess these small so called "quiet" Honda's are too loud according to you????
Quiet Generators - What is the Quietest Portable Generator?
fella10 is offline   Reply With Quote
Old 09-09-2016, 03:33 PM   #12
if you mean cheap as in half the price, yes it is. But it is a by far better value than the Honda. and the noise ratings are the same
2015 Ram 2500 4x4 6.4l with 2015 Flagstaff 21FBRS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 09-09-2016, 03:43 PM   #13
The Honda EU3000IS rated at 58db is way much better then the Champion, but the call is your buddy. Happy Trails......
goots is offline   Reply With Quote
Old 09-09-2016, 04:03 PM   #14
Moderators' Assistant
bikendan's Avatar
He's talking about the INVERTER 3400w Champion, which is almost as quiet as the Honda 3000.
Dan-Retired Firefighter/EMT
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 09-09-2016, 04:41 PM   #15
I like my Champion 2000 watt inverter generator. It is quiet. It only gets occasional use, mostly at my house, but it always starts and runs well.
2015 Micro Lite 25KS
2006 Suburban 2500 8.1 L
220Chap is offline   Reply With Quote
Old 09-09-2016, 05:25 PM   #16
2012 FR Lexington 283TS
Champion Portable Generator
I recently bought a Champion 3,500W Running/4,375W Peak portable gas generator. It only weighs 100 pounds. This is rated at 30 amps (which is what my motorhome is rated). It is rated at 68db. It is slightly louder than our Honda Inverter but it only cost us $389.00 though Costco (free freight). We have a 4000W Onan built in to the MH but when camping with the whole family, we needed an additional generator. My son can run everything in his trailer (including a/c) without any problems. The power lead from the MH plugs right into the generator. If you read the reviews, Champion is rating better than most other manufacturers (they actually make generators for a bunch of other companies) and at a better price. It has a great two year warranty. How many of the Champions can you buy for the price of one 3,500W Honda??? I know that we have about 120 hours currently on the generator and have had no problems.
CaboSnow is offline   Reply With Quote
Old 09-09-2016, 05:50 PM   #17
that 58dB 3000/2800w Honda inverter gen. is $2,095. on Amazon,
that 59dB 3400/3100w Champion inverter gen. cost me $997.77,
by today's math, that 1dB cost $1,097.23,
by all measures that's a very expensive dB,
plus that Honda comes with LESS power(watts), 400w less start/300w less run,
again, .... no thank you, I'll take my chances with the cheapo,
but thank you for trying to help me see the light,
Old 09-09-2016, 09:14 PM   #18
I have the Champion 3100w inverter generator which I purchased at Costco for $699.00. It easily starts my 13.5k A/C and will even run the A/C and microwave at the same time (which we have done by accident a couple of times).
At campgrounds I've made a point to compare (unscientifically) my Champion to the Honda eu2000 which seems to be the most prevalent inverter generator that I see other campers with. I know the Honda is quieter according to the specs, but in my walk-around sampling it seems to me that the difference in loudness is more a fuction of positioning on the site and where you are relative to the exhaust outlet. Bottom line I can't tell tell a real-world differnce between the two while camping.
I usually reserve perimeter sites and point my exhaust away from me and others. I realize this is not always possible.
IMO the Champion 3100 is the best value going.
Steve, Barb, and 5 daughters who love to camp
2017 Shamrock 23IKSS, Yellow sticker: 5314 lbs, Equil-i-zer 4pt. 1,000/10,000
2006 Fleetwood (Coleman) Niagara: Sold!
2003 Suburban 1500 Z71, 5.3/3.73, airbags, LT tires, Big Brake Upgrade, Prodigy P2
Shamrockthecasbah is offline   Reply With Quote
Old 09-09-2016, 11:22 PM   #19
generators
If you are plugging in a 30 amp trailer and want to run, as you say everything, you need at least a 3600 watt generator. 30 amp X 120 volt = 3600 watts. When the ac starts it can draw way more than the 13.5 - 14 running amps so you might want to not be running any other high resistive loads if you are running the ac. There are a lot of generators that have a rv 30 amp connector. If noise is an issue, read the specs and find one that has the lowest db and balance that with the price you want to pay.
markb422 is offline   Reply With Quote
Old 09-10-2016, 12:13 AM   #20
Be sure you have enough amp power in your generator to run what you want to run. Plugged into shore power, you can go over your amp/watt draw for a few seconds, but with a generator you have what you have. Take a look the attached chart showing amp draws for various electrical items you may have in your RV.
tomrob1161 is offline   Reply With Quote
generator, rockwood
