Old 09-08-2016, 01:47 PM   #1
What size generator - 2017 Rockwood 2504S
I looking to buy a portable gas generator for my 2017 Rockwood 2504S travel trailer that will handle running everything. I want make sure I purchase the right size, do you know what size I will need. Thanks for your help. I'm hoping someone here has the same trailer and knows what size works. I have searched sites and in the Forums and have not seen the answer.
Mike
Santa Rosa, California
Bracewell is offline   Reply With Quote
Old 09-08-2016, 01:50 PM   #2
craigster_mi's Avatar
Mike
I'm also interested in the answer to this question so hopefully good info is to follow.
craig
2014 F150 Eco
2015 Rockwood Mini-Lite 2504S
craigster_mi is offline   Reply With Quote
Old 09-08-2016, 02:11 PM   #3
Georgia Frog Rally 2017
aceinspp's Avatar
Do a search as there have been plenty of questions and answers to this question. You also need to furnish more info on what you are wanting to run and btu of ac. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped so far 2017 15
Days booked so far in 2017 37
aceinspp is online now   Reply With Quote
Old 09-08-2016, 02:16 PM   #4
fonzie's Avatar
X2
https://www.google.ca/search?q=gener..._sNcLzUJTPlNgH
Fonzie
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36)
Old 09-08-2016, 02:56 PM   #5
Moderators' Assistant
bikendan's Avatar
As was said, there is a ton of posts/threads here that can provide you plenty of information.
But here are some basic questions :
Do you plan on using the generator in a campground?
Do you want quiet or cheap?
Do you want to run the a/c?
If so, what size is your a/c?
Seeing that you're in Sonoma County, I'm assuming that you want a generator for staying at California State Parks.
As former California residents, who primarily camped there, we got a Honda 2000i inverter generator.
We rarely needed to run the a/c so it is perfect for us.
Dan-Retired Firefighter/EMT
2016 PrimeTime TracerAIR 255, pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 09-08-2016, 04:19 PM   #6
Thank you
Thank you, what size trailer do you have? Does the 2000 run everything at once?
Mike
Old 09-08-2016, 06:17 PM   #7
bikendan's Avatar
Mike
I have a 24' HTT with a 13.5k a/c.
It will run everything at once except the a/c.
But there's no need to run the fridge and WH on generator. Run them on propane.
Old 09-09-2016, 01:19 PM   #8
I have the model MiniLite 2304. I installed an Onan
2500 watt propane generator on it. Handles everything but not the A/C. I should mention that we only run one of the following at any one time:
- hair dryer
- coffee maker or
- toaster
If you're careful like above even a 2000watt will do the job.
Ian Walker is offline   Reply With Quote
Old 09-09-2016, 01:52 PM   #9
Mike, we have the Micro Lite 25KS a twin to the Mini Lite 2503S, so its about the same size as your trailer, our Champion 3400w model 100261, inverter gen. is due to be delivered on Monday,
from the research I've done it is fully sufficient to handle our 13,500 ac, plus enough other stuff to be comfortable, its almost equal to having two of the 2000w connected in parallel,........ it has elect. start with wireless remote(that should be a very handy item) $997.77 full price, free shipping, no tax, ... there isn't an extended run system for that model YET, but Champion says they are aware of the demand for it and imply they are considering it,..... anyway you may be interested in it, ... link below to the lowest price I found......
Champion Inverter Generators
fella10 is online now   Reply With Quote
Old 09-09-2016, 02:01 PM   #10
Get a Honda 3000 watts gen. the Champion is to loud and cheap
goots is offline   Reply With Quote
generator, rockwood
