Old 10-18-2013, 05:10 PM   #1
What size generator needed for 15000 Air
I,m planning to buy a generator for dry camping. Does anyone have any experience with using a Honda eu3000 to run there air? I have a 15000 unit.
Steve
scantril is offline   Reply With Quote
Old 10-18-2013, 05:20 PM   #2
dcheatwood's Avatar
3000 watts and up. Might get by with a 2800 in the right brand. Others will reply with greater detail. But 3000 will run ac.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 10-18-2013, 06:04 PM   #3
Phat Phrog Stunt Crew
awwall's Avatar
3000 should run it with no problems!!
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 10-18-2013, 10:22 PM   #4
dcheatwood's Avatar
Steve
Father in law has one. Very quiet, easy to start and runs ac and other accessories. But $$$.
Old 10-19-2013, 03:22 AM   #5
sail2liv's Avatar
I have a champion 4000....it runs the a/c 15000.....but I put the surge protector on it and get intermittent reverse polarity when a/c running....with that decided not to run a/c....but it runs all else fine and surge meter stays normal.....I have not checked it with everything but the a/c shut off////that might take care of the reading
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
sail2liv is offline   Reply With Quote
Old 10-19-2013, 06:12 AM   #6
i bought the champion 3000i. works great on my tt. runs the 15k ac, fridge and television. i havent tried to run much else. it is a lot cheaper in cost than the honda and just as quite
2013 Ram 1500 (5.7)
2014 Rockwood Mini Lite 2104s
http://i307.photobucket.com/albums/n...ps412bc14c.jpg
Prothos is offline   Reply With Quote
Old 10-19-2013, 06:25 AM   #7
Herk7769's Avatar
You may need to make a bonding plug for your generator. A regular house type socket with the neutral and ground connected with a jumper that you plug into the 20 amp outlet of your generator should solve that.
More here:
Generator Ground-Neutral Bonding | No~Shock~Zone
HAM CALLSIGN - KC3FFW
Old 10-19-2013, 04:48 PM   #8
bikendan's Avatar
I have a champion 4000....it runs the a/c 5000
just realize that this is an open-framed contractor generator and is great for Boondocking or motor races but not for a campground.
way too loud for being close to others, unless it's at a Nascar event.
the new Champion 3100w inverter generator would be a much better choice for use in a campground with no hookups, meaning dry camping.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
500, generator
