What the heck is with this electrical/lighting problem?
GO TO TUrn on the light above my couch (not halogen) in my new 365saqb sierra and not work(its one with 2 bulbs and a push in type switch)and the light did not work, look at bulbs and both burned out and BLACK!! put in new bulbs,,,,not work,,,,,,check fuses, they all are good. pulled down the light and checked the wires all look fine-all attached and not scorched or anything. What could have happened? everything else works fine in the rv. Could it be the switch in the light? And whats with the red lamps in the fuse box? when you pull the fuse on some of them a red lamp comes on that looks like its to tell you you have a "dissconnect" (bad fuse), some of the red lights come on when you pull the fuse and some do not??? but all is working??? anyone here have any ideas?
