Old 12-08-2015, 05:12 PM   #1
where did you mount battery disconnect
Where to put it, on the frame up front by the battery, on the battery case, just let it hang?
2015 grey wolf 27RR
2015 Chevy 3500HD
kcmusa is offline   Reply With Quote
Old 12-08-2015, 05:14 PM   #2
fonzie's Avatar
Lots of threads on subject......
https://www.google.ca/search?q=batte...ConOjwTBtpTABg
Fonzie
Old 12-08-2015, 08:18 PM   #3
I mounted a marine dual battery shutoff on the end of the battery box. Now have 6V batteries so only use part of switch.
Fred W
Old 12-10-2015, 06:55 PM   #4
Did ours today. Put it on the negative battery terminal.
2016 Salem Hemisphere 302FK Showstopper
2017 Silverado 2500HD Duramax, LTZ, crew cab, Z71, 20" tires, TST 507 tire pressure monitor
DiverDennis is offline   Reply With Quote
Old 12-13-2015, 09:11 PM   #5
Blackhat6mike's Avatar
There are several types of cutoff switches to choose from. Weigh them all out for your specific need. Mine is a four-way Perko marine switch with the choices of bat#1, bat#2, both or all off. One switch in one place anywhere it's easy to get to. Some install their switch on the neg line, although I have no idea why. Mine is on the positive side just like in my boats which came from the factory that way.
Oh, and good luck with the Optima bats. I'm sure you paid dearly for them. What total amp hours will they deliver?
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 12-13-2015, 09:28 PM   #6
muddyrode's Avatar
I put in an race car style off/on switch and mounted it on top of the battery box that on my fw so its inside out of the weather
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
muddyrode is offline   Reply With Quote
Old 12-14-2015, 07:12 AM   #7
....Oh, and good luck with the Optima bats. I'm sure you paid dearly for them. What total amp hours will they deliver?
Battery Model: D31M
Part Number: 8052-161
Capacity: 75 Ah (C/20)
Reserve Capacity: BCI: 155 minutes (25 amp discharge, 80F to 10.5 volts cut-off)
Amazon - $216
battery, battery disconnect, mount
