Old 11-11-2015, 07:03 PM   #11
Originally Posted by bmaggin1 View Post
Just put one of these on my motor home.. I came with everything that you need and a MPPT controller so you can run the 100 watt panels at 24 volts instead of 12v.. The controller will convert the 24 volts to 12 to charge your batteries..
200 Watt 12 Volt Monocrystalline Premium Kit | Renogy Solar
So, what's the advantage to 24v versus 12v? IF you go with 24v, what do you have to do different with the panels? Just asking why!
MOODMAN is offline   Reply With Quote
Old 11-11-2015, 07:17 PM   #12
SCCS's Avatar
gpelectric.com excellent source of information.
SCCS
15 F150 xlt pulling
15 Forest River mini-lite 2502s
SCCS is offline   Reply With Quote
Old 11-11-2015, 07:22 PM   #13
KMP44's Avatar
Got mine from solarblvd - very happy with the system and the price.
https://www.solarblvd.com/index.php?cPath=1_272
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 11-11-2015, 07:47 PM   #14
Solar PV panels are now widely available with prices coming down almost daily. You should be able to find a good mono panel for about $1.50 a watt. Outback just released a small MPPT controller that outputs up to 20 amps (for 12 volt system) with selectable charging regimes for lead/acid and AGM batteries. This controller will work well with a 200 watt panel.
DRiveWell is offline   Reply With Quote
Old 11-11-2015, 09:27 PM   #15
RailwayRog
What do you guys think of this one? Just need a controller.
Grape Solar 100 Watt Polycrystalline PV Solar Panel
RailwayRog is offline   Reply With Quote
Old 11-11-2015, 10:14 PM   #16
Have bought panels and parts from this suppler (fred480v). He is a wholesaler who picks up end of run or over stock. If you see what you want buy it now stock changes fast and never the same.
fred480v | eBay
Hope This Helps Tim
TimVWulp is online now   Reply With Quote
Old 11-12-2015, 01:32 AM   #17
Tom48's Avatar
Originally Posted by silver View Post
I am looking at that kit. When you say everything did you get the fuses? I did not see those in the description and thought I would need to get separately.
You will manage to spend a bit more at an auto part store or similar to put 20 or 30 amps blade fuses on both the solar array side and the lead to the battery. You ought to order 10 ga wire as an option with the kit which comes with 12 ga by default. You will also want some crimp on loops to take the Positive to the Battery post and the Negative to the a frame ground or the battery post. I have done or helped on several installs and you may well need a roll of 10ga stranded copper wire for your run from controller to battery and wire ties as well as some inch or inch and a quarter #14 stainless sheet metal screws to mount the panels to the roof as well as a tube of self leveling Dicor or similar to caulk every point that you penetrate the roof. Some blue or red loctite to make sure the screws holding the panels to the mounting brackets never back out might not hurt.
Its a KIT but you still need shop supplies to install it
Tom48 is offline   Reply With Quote
Old 11-12-2015, 01:35 AM   #18
Tom48's Avatar
That is just the panel you still need mounting brackets and special water tight connectors and 10 or 12 ga wire to connect panel to controller and controller to battery SO sounds nice that it is only $129 put you need the kit for ease of rv install
Old 11-12-2015, 01:38 AM   #19
Tom48's Avatar
Most good controllers will take a "12v or 24V" input two in parallel is 12 v two in series is 24 v. At 24 volt you can carry more on thinner wire. Some controllers start working in lower light at 24 input than on 12 input but we did some tests on the drive way and it did not seem to make too much difference.
Old 11-12-2015, 06:22 AM   #20
Read this first
https://handybobsolar.wordpress.com/...ging-puzzle-2/
This site will tell you what you need to know. I put 100 watt panel on my Roo, with a Morningstar controller. I have two batteries, and led lights, and it will run everything I need, including running the furnace for a couple of hours in the morning until the sun comes up. I don't run my furnace at night because it wakes me up. I purchased my flexible panel from a guy on eBay who sells out of Albuquerque. Convenient, since I live here. I attached my panel with silicone. I tried to remove my last solar panel when I sold my camper, and gave up. Critical to have large wire from panel to battery, I like circuit breakers better than fuses (you can get them at auto supply store).
mnoland30 is offline   Reply With Quote
solar, solar panel
