Old 06-24-2013, 09:46 PM   #1
Where is B.I.R.D.
Have a 2010 Solera 2008 chassis. Can not find the bird. Engine does not charge the coach battery.
eddiestash is offline   Reply With Quote
Old 06-25-2013, 08:57 AM   #2
Herk7769's Avatar
OK, I will "bite"; what is the bird?
Are you referring to the BCC (Battery Control Center)?
HAM CALLSIGN - KC3FFW
Old 06-25-2013, 09:25 AM   #3
Bi directional relay delay (bird) It controls how and where battery charges. Can not find it. The BCC is a fr500r by Rv custom products. It has the Solenoid connecting the coach and chassis battery.Also controls steps awning and few other things. There are two wires connected to soleniod other than main connection which should engage solenoid. I have tested solinoid. BCC solenoid works fine. The bird should have a wire to the ignition to activate and then energize solenoid. If the bird is an intellitech which if I could find it would know for sure has a 2.5 minute delay before it charges chassis battery from alternator. I need help in locating the bird. Coach battery does not charge from alternator.
Old 06-25-2013, 12:21 PM   #4
Herk7769's Avatar
This is all I have.
Let me know if you find more.
File Type: pdf BiDirectional Isolator Relay Delay.pdf (105.0 KB, 26 views)
Old 06-25-2013, 01:01 PM   #5
Hard to read thumbnail . Pretty much know how wired just need to find it.
Old 06-26-2013, 07:30 AM   #6
Can u rescan cant quite read diagram
Old 06-26-2013, 11:42 AM   #7
Herk7769's Avatar
Sorry, it was a download of someone else's post.
This PDF might be better than the jpg.
Old 06-26-2013, 01:54 PM   #8
VinceU's Avatar
Under steps?
Old 06-26-2013, 02:07 PM   #9
Coach steps?
Old 06-26-2013, 02:23 PM   #10
VinceU's Avatar
Coach steps?
Yes some C's had access under entry steps. Another easy way to find it. Have someone flip disconnect off/on and locate the sound. Thats the relay.
