Old 03-17-2013, 05:02 PM   #1
Where is it?
My converter charger. I have a 2006 Cedar Creek Silver back Fifth Wheel model 29LRLBS.
My rig is still winterized and on one of my checks I noticed that my battery bank was dead.(6 six volt golf cart batteries). I got them fully charged so now I need to repair or replace the converter charger. I think its under the breaker panel,not sure. If it is do I get to it from the front or from the front compartment? If I remove the shore line and turn off the battery switch will that cut the power or do I have to remove the ground cable ?
I have another question on my level up system. Is the place to post it or ??
DKean is offline   Reply With Quote
Old 03-17-2013, 05:10 PM   #2
TURBS's Avatar
Welcome to the forum.
What brand is your distribution center?
If its a wfco then yes depending on model it will be inside.
Fyi I would imo replace it with a progressive dynamics brand.
Turbs
Old 03-17-2013, 06:05 PM   #3
Thanks for your quick response. It is what ever Forest River installed when they built it. I guess I'll start trying to remove the front cover and use my volt meter to check for live wires.
I would think any replacement would have the same wires to hook up?
Old 03-17-2013, 06:18 PM   #4
TURBS's Avatar
Disconnect shore power before removal of course.
If you open the cover the model and make is listed.
Old 03-17-2013, 06:21 PM   #5
TURBS's Avatar
Old 03-17-2013, 06:24 PM   #6
Denver, CO
garbonz's Avatar
You will have to pull the circuit breaker box and look behind, or it may be attached to the box itself.
2017 Fuse 23T
Old 03-17-2013, 07:07 PM   #7
caper's Avatar
Remove the plastic cover. The convertor is located on the bottom to the unit.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
