Old 09-08-2015, 09:42 AM   #11
OBX Forever's Avatar
Ours is in the bathroom.
Shouldn't there be two?
~~Mark & Peggy~~
2014 Coachmen Freedom Express 305RKDS (stolen, found, and traded)
2015 Heritage Glen 302FK
pulled by 2012 Dodge Ram 2500 Diesel
OBX Forever is offline   Reply With Quote
Old 09-08-2015, 10:26 AM   #12
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
it all depends on whether there're two circuits protected by the GFI's.
Grampa Jim is offline   Reply With Quote
Old 09-09-2015, 02:06 PM   #13
Pockets
Mine's in the bathroom. And if it won't reset, I have a circuit breaker in the distribution box/.
Bob & Kelley
2015 Flagstaff 26RBSS
2014 FORD F-150 Supercrew 4x4
3.5L Ecoboost, 3:73 axle, Max Tow Pkg
2015(36 nights) 2016(74 nights) 2017(174) 2018(105 nights)
Pockets is offline   Reply With Quote
Old 09-09-2015, 02:07 PM   #14
Pockets,,,,,it's defective if you can't reset it and it's not tripping because of a bad circuit short.
Old 09-09-2015, 02:26 PM   #15
Pockets
Grampa Jim. What I meant is I also have a circuit breaker for the GFCI. Once when I was using the toaster and a portable space heater, it tripped the GFCI at the plug. When I reset it, it wouldn't reset until I reset the circuit breaker. Once I did that I was able to reset the GFCI at the plug. Just saying.
Bob & Kelley
Old 09-09-2015, 02:28 PM   #16
Oh,,,,,,I was misinterpreting your situation.......yup,,,,your GFI is still good. My bad.
Old 09-19-2015, 09:27 AM   #17
I am having same problem with no lights in bathroom and bedroom gfci seems to work fine in bathroom as use a nite lite it trips same in kitchen changed every fuse I could find and those were only 2 I found outlet outside is not gfci and don't see one anywhere under awning 2007 30ft cardinal any help greatly appreciated
ehgolf is offline   Reply With Quote
Old 09-19-2015, 10:03 AM   #18
GFI's have a tendency to go bad. That might be the problem too.
Old 09-19-2015, 10:13 AM   #19
Both have electricity to them and will trip/reset ok. Could that still be the problem.
Old 09-19-2015, 10:17 AM   #20
Where the terminals from the battery go into the wall there are 3 looks like a relay I tried reserving them the little button won't stay set don't know if that could be it but seem weird all 3 would be bad especially when other 12 volt lights are working.
