Where to have Xantrex inverter, solar system installed, worked on
I'm new to posting here. Does anyone know where to have inverter/solar/generator system worked on here in the San Antonio or Austin, or even Houston, TX areas? I have had a high-end Xantrex inverter, Victron BMV 712 battery monitor, and Victron solar control charger installed, but, even though the inverter works, I don't think things are hooked up quite right cause I'm getting unexpected readouts from the battery monitor. I don't trust the RV repair shop that installed the inverter and battery monitor because of this and other mistakes they made and can't seem to find any competent shops that know enough about these systems. I also need the Xantrex Automatic Generator Start installed. Thanks for any help you may have!
B and L Carey
2019 Riverstone 39RKFB
2016 GMC Sierra 3500 HD DRW
