Old 03-01-2016, 07:46 AM   #1
Where's the fuse at?????
Hey Guys,
I have a 2011 Coachmen Cross Country 405FK. I have two interior light switches on the wall beside the sink in the kitchen that operate the interior light. Each toggle type switch operates a set of four light. The switch for the front set of lights nearest the cab will no longer turn on the lights. So I began my normal diagnostic trying to find the fuse or the problem.
Well, I have searched my whole unit over. I have checked every fuse I can find TWICE!!! and I still cannot find the fuse for this set of lights. I cant find a fuse anywhere that is connected to the interior lights at all.
Am I missing something?
I thought there would be a fuse for the lights. There seems to be one for everything else.
So, I'm lost and need your help.
Do you have any ideas?
Oh....and I forgot to add....the switch plate does not appear to have any type of screw in it so you can take it off the wall and check it!!! ugh!!!!
Thanks for your time!!!
retiredchief is offline   Reply With Quote
Old 03-01-2016, 07:56 AM   #2
bubbles's Avatar
If the switch is actually a rocker switch it probably has a bezel that just pushes on from the front and is removed by pulling the bezel off exposing the switch housing which is held in place with screws. If this switch is in a switch panel and not just on the wall then a different story. Without picture can't be real sure of all I've said.
