Old 08-12-2013, 07:11 PM   #21
Originally Posted by Chunkychuck View Post
Yes, the RV came with an adapter to take the 50 amp plug to a 30 amp plug.
You are good to go, just remember you are going to be severely power deprived in that configuration.
Acableguy06 is offline   Reply With Quote
Old 08-12-2013, 07:16 PM   #22
Chunkychuck's Avatar
I know. I just need something right now to be able to recharge my battery and run lights and water pump.
2013 Brookstone 340LS Ruby
2014 Dodge 3500 Diesel
Chunkychuck is offline   Reply With Quote
Old 08-12-2013, 07:17 PM   #23
The genny does not decide weather 120 or 240 is put out. Its what we plug into it. If you plug a twist lock into that plug with only one of the hots tied to it it is 120 if you plug a twistlock into it, with both hots tied to it, its 240.
And even this is partially true. It is only 240 if you measure leg to leg. And 240 is only utilized if you plug in a 240 volt appliance. Otherwise its still 120 per leg and each leg can be used as 120.
Old 08-12-2013, 07:59 PM   #24
Batts-toy's Avatar
Evidently I wasn't clear with my statement. The gen has not been modified. The electrician fabricated a cable with the house plug on one end and a plug that fit the gen on the other end.
Sorry my bad I went back and re-read your question you said it correctly I read it wrong.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 08-12-2013, 08:18 PM   #25
B and B's Avatar
Originally Posted by f1100turbo View Post
With that being said I had a qualified and competent generator expert rewire my gennie and he eliminated that 4 prong 120/240 oulet and put in a 30 amp rv receptical.
It has worked flawlessly for over a year now.
Turbs
I second that, qualified personal. Being a single sided single phase load the other half of the winding will run unloaded. Depending on how the generator regulates this may have to be taken into consideration.
The local Home Depot has these on clearance for $199.00
3500 watts with a 30 Amp RV Plug built in.
Brian
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 08-14-2013, 01:38 PM   #26
Took some pictures when I hooked up this morning. There is a wire screw holder where it says "neutral bonded to frame" Should I be attaching something to it. There is also a 120 20a 3 prong twist lock to the left of the 4 prong 120/240 I am going into now. Would it be a better option? Thanks for all the help.
Old 08-14-2013, 08:39 PM   #27
Is this manual for your generator?
http://www.mitsubishi-generators.com...-5800-6700.pdf
Is that a 20 amp or 30amp 120 twistlock? You should have a switch on your panel somewhere to select 120 only or 120/240.
Old 08-15-2013, 10:36 AM   #28
That is the manual. Looking closer it is a 30 amp 120 twist lock. The gen does have a select switch for 120 or 120/240. I hadn't looked real close as the electrician had chosen to use the 20 amp 120/240 plug to supply the bypass box in the house. That kinda locked "MY" thinking into that would be the best for the RV as well. Another lesson in what applies in one situation doesn't necessarily work the best in another situation. Will be getting adapter as soon as practical.
Old 08-15-2013, 10:47 AM   #29
B and B's Avatar
All that is required is a twist to RV adapter and you are good to go for 30 amps. Be safe, have it checked by an electrician if you are unsure .
Brian
Old 08-15-2013, 04:38 PM   #30
djmac1964's Avatar
After reading this, I'm glad the generator I bought already had the 30amp RV outlet on it!
Don
2013 XLR 27HFS Toy Hauler
2014 Silverado 2500HD Z71 Crew Cab
99 Club Car Golf Cart
djmac1964 is offline   Reply With Quote
generator
