Old 08-15-2013, 04:44 PM   #31
Chunkychuck's Avatar
Originally Posted by djmac1964 View Post
After reading this, I'm glad the generator I bought already had the 30amp RV outlet on it!
May I ask what brand? I probably will purchase new in the near future but at least for now I can use my current generator. It was really quiet for the late 90's generators (70 dbs) but I guess is pretty loud compared to the new ones.
2013 Brookstone 340LS Ruby
2014 Dodge 3500 Diesel
Chunkychuck is offline   Reply With Quote
Old 08-15-2013, 05:17 PM   #32
djmac1964's Avatar
It was a Champion 3500/4000. Bought it from Home Depot online. Was around $450 deliverd to my home with free shipping. Had the 30amp RV receptical, the 30amp 4 prong twist lock plug, 2 110 outlets, elictric start, and the remote start key fob, so you can start it and shut it down from inside the camper.
Don
2013 XLR 27HFS Toy Hauler
2014 Silverado 2500HD Z71 Crew Cab
99 Club Car Golf Cart
djmac1964 is offline   Reply With Quote
Old 08-15-2013, 05:20 PM   #33
djmac1964's Avatar
We used it on our trip to FL this summer, when we pulled into a rest area to sleep. It ran the ac great, and used about a half tank of gas over about a 6 hour period.
Don
Old 08-15-2013, 06:06 PM   #34
Originally Posted by Chunkychuck View Post
That is the manual. Looking closer it is a 30 amp 120 twist lock. The gen does have a select switch for 120 or 120/240. I hadn't looked real close as the electrician had chosen to use the 20 amp 120/240 plug to supply the bypass box in the house. That kinda locked "MY" thinking into that would be the best for the RV as well. Another lesson in what applies in one situation doesn't necessarily work the best in another situation. Will be getting adapter as soon as practical.
Yep getting the 30 amp 120 to rv plug is definitely the best bet as that will give you the full power of the generator. If I recall from the pic you posted about 27 amps or so continuous. Just set the switch to 120 only and plug in. If your generator is up to par you should be able to run the A/C in your rig as well, at least the main one if you have 2 of them. Cant run both on a 30 amp hook up.
Acableguy06 is offline   Reply With Quote
Old 08-15-2013, 08:24 PM   #35
Only 1 AC. It has an auto-idle switch. I imagine probably ought to stay on full power if running air and can use auto-idle the rest of the time under average circumstances.
Old 08-15-2013, 08:50 PM   #36
Would probably be best to leave on full speed when running the air, provides a more stable voltage. If it is at a low idle when the compressor kicks in there is a bit of a delay for everything to kick in for the genny to get up to speed to compensate for the large load being dropped on it. This creates a low voltage scenario that compressors and motors do not like. Will shorten the life of the electronics over time.
generator
