Old 09-14-2016, 02:02 PM   #11
Devilscreekw's Avatar
Every one I've ever owned is white to negative [ground] and red to positive.
Harv & Deb
2015 Flagstaff 27RLWS
2010 Ram 2500 4x4 crew 5.7 Hemi, 3.73
Equalizer 1200 4 pt. Tekonsha controller
Devilscreekw is offline   Reply With Quote
Old 09-14-2016, 07:14 PM   #12
The fastest way is what DDC said, the positive post on your battery is always a bit bigger in diameter than the negative post.
D-Man is offline   Reply With Quote
Old 09-14-2016, 09:50 PM   #13
txkreddog
txkreddog's Avatar
Mine is the same, Red positive, white negative.
txkreddog is offline   Reply With Quote
Old 09-15-2016, 05:36 AM   #14
Thanks. So having a red and white wire is not shotty wiring just another way for a certain manufactures. I will crawl under and follow wires to thier source before I reconnect battery. Wish I looked when disconnecting but it was getting dark and just pulled them quick didn't even notice. I will then tag them so there is no confusion
Boborc is offline   Reply With Quote
Old 09-17-2016, 06:49 PM   #15
Making an assumption is not helpful. I have found different color schemes in my MH. I suggest (1) using a multimeter or tracing back wires if possible as previously stated and (2) if you don't know for certain, don't respond.
Sue and John
29RLBS Wildcat
2008 F350 Lariat
2USARetired is offline   Reply With Quote
Old 09-17-2016, 07:13 PM   #16
Flybob's Avatar
I would never trust the wiring color scheme to be standard on an RV. I have seen too many that were completely counterintuitive . I would always trace the assumed ground wire to the frame connection. It is usually not far away.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 09-29-2016, 08:12 PM   #17
Originally Posted by flybob View Post
if you use this method, make sure you are not connected to shore power ( converter on) as measuring resistance on between the "+" side and ground could damage or destroy the meter.
battery must be disconnected as well!!!!!!
Jim in Halifax is offline   Reply With Quote
Old 09-30-2016, 08:58 AM   #18
Too Tall's Avatar
I have never seen red being anything else but positive regardless of voltage or application.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
