Old 09-14-2016, 06:52 AM   #1
Which is positive negative
This stuff only happens to me. Went to connect my battery back up and noticed I have 1 red wire and a white wire. On cars its balck (-) Red (+). On TT its supposed to be White (- or common) black (+) like home wiring. Of course I get a what ever you want to call it.
Boborc is offline   Reply With Quote
Old 09-14-2016, 06:56 AM   #2
I'll have to crawl under and make sure. I assume white is negative and red positive.
Old 09-14-2016, 07:34 AM   #3
jeff
jeff64's Avatar
If you are in doubt, follow the wires. If the white wire goes to the frame of the TT it is a ground. If the red wire goes to terminals, breakers or battery disconnect switch it is positive
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 09-14-2016, 07:49 AM   #4
Use a multimeter to be 100% sure if you can't follow wiring back to battery.
Skyliner is offline   Reply With Quote
Old 09-14-2016, 07:51 AM   #5
Quick way to find out. Break out your meter and ohm the wires to the trailer frame. Whichever wire (I'll bet the white one) reads 0 ohms is the negative. Once you figure it out, wrap the last 6 or so inches of the ground with black electrical tape so in the future there is no question.
limblips is offline   Reply With Quote
Old 09-14-2016, 08:25 AM   #6
Check your frame around where the battery box is, after trying to figure out which wire was which this spring, I finally noticed a sticker saying which one was positive/negative. Not sure if all trailers have this or not, but it sure was helpful.
Yuri is offline   Reply With Quote
Old 09-14-2016, 08:30 AM   #7
DDC
DDC's Avatar
If the battery has round posts you will notice that one has a larger diameter that the other, the large one is positive and the smaller one is negative.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 09-14-2016, 08:56 AM   #8
clr
When all else fails read the installation instructions for the back up camera. When I installed a Peak back up camera the red lead was positive and the white lead was negative. Would assume that is also the case for you.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 09-14-2016, 02:26 PM   #9
I always check with a multimeter. If not, you assume the assembler did everything correctly. I am not willing to put my faith in that. Check for yourself.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat 4X4 6.4 Diesel
42 nights camping in 2015
61 nights in 2016 (still not enough!)
ben31 is offline   Reply With Quote
Old 09-14-2016, 02:49 PM   #10
Flybob's Avatar
If you use this method, make sure you are not connected to shore power ( converter on) as measuring resistance on between the "+" side and ground could damage or destroy the meter.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
