Old 02-23-2016, 12:00 AM   #1
flymhi's Avatar
which mounts for solar panels?
I just sold our 21SS which I had mounted a 160W panel with aluminum brackets/lag bolts and lots of sealant.
Getting things in order for the arrival of the new unit and debating on mounts for the new 175W panel. I've seen these no-drill mounts and wondered about the tradeoffs. I would still drill into the aluminum frame of the panel, but instaed of penetrating the camper roof, would sealant/glue be enough to hold down the panel at highway speeds? If they ever come off, they would likely rip the rubber lining from the roof. Contemplating six mounts pictured below. Probably would mount 3 across the front as an airfoil to prevent much wind from getting under the panel at speed. Youtube reviews show these to be really beefy. I'm sure they would fade over time as any plastic would.
Any feedback? Is anyone currently using these on their roof?
2015 Denali Duramax 2500
2017 Coachmen 229TBS
2010 Shamrock 21SS - sold!
flymhi is offline   Reply With Quote
Old 02-27-2016, 01:23 PM   #2
What brand is that mount or where did you find it?
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is offline   Reply With Quote
Old 02-28-2016, 11:44 AM   #3
I prefer mounts that secure to the roof and don't mind screwing thru the membrane to do it. Dicor and eternabond are sufficient to seal the roof and prevent leaks.
I heard of a couple horror stories on new campers having problems with roof caps and membrane roofs blowing off on the drive home from the dealership.
Skyliner is offline   Reply With Quote
Old 02-28-2016, 05:50 PM   #4
flymhi's Avatar
Looks like from the amazon reviews that they are not suited for RVs with not being screwed down.
I used aluminum angle brackets on our last unit and did not have any issues.
mount, solar, solar panel
