11-24-2016, 10:51 PM
Who should fix this?
The little ridge on the trailer outlet cover on my Toyota 4runner, that holds the trailer plug in, broke on one of my first excursions with my Clipper 17bh. Unfortunately, the plug from the trailer dragged on the road for a bit so that even if the vehicle outlet was intact, the raised part on the actual plug is worn down so much that it probably wouldn't hold.
I've been getting by for over a year by holding the plug in with zip ties but it's a giant pain on the *** and I'd like to get it fixed.
Would I go to a mechanic for the truck and rv dealer for the the plug, or could the rv place OR the mechanic fix both?
I'm hoping it is a relatively simple job?
Carmen and the pack
2015 Coachmen Clipper 17BH
2017 Dodge Durango Citadel 5.7 Hemi
11-24-2016, 11:00 PM
I use to be a mechanic full time. I would fix both the TV and TT as long as I had space to have them both there.
11-24-2016, 11:03 PM
The RV dealer will have the parts in stock, the mechanic will order it or get it from the parts store.
Either would be qualified to do the job.
2015 F-250 FX4
11-24-2016, 11:04 PM
You might be able to go to a junkyard to get replacement part for your 4Runner. Could be as simple as removing a couple of screws, a clip or two, and a disconnect a plug. I can look at one tomorrow to see if it is that easy.
Replacing the cord end on camper would not be that difficult either. Replacement plugs can be found in any auto parts store.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
11-25-2016, 12:20 AM
Where do you live? I know some people that work at Toyota.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
11-25-2016, 07:57 AM
I'm in Burlington, Ontario, Canada
Carmen and the pack
11-25-2016, 08:24 AM
Check etrailer.com. They may have a solution.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
11-25-2016, 08:35 AM
There is a lot of information on this site and some videos on YouTube on how to replace these.
I would do a lot of reading and make a large bowl of pop corn for the videos and then do it myself to save some serious coin and down time.
It can be done with basic tools and lots of patience and rechecking your work.
11-25-2016, 10:01 AM
Get a factory Toyota socket and a new TT plug end. They sell replacements for the trailer end that are easy to install. I put one on my trailer 9 years ago and all is still good. I don't like the replacement 7-way sockets as they are usually very cheaply made.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
11-25-2016, 01:05 PM
Director, FROG
On an ongoing basis, you might want to use a 6" bungee to hold the end of the electric cable into the socket as you drive. It's cheap insurance against the cord coming out an falling on the ground again, or at least loosening to the point where you don't have a good connection on your trailer lights -- in our case, the lights on the toad behind our motorhome.
11-25-2016, 01:11 PM
Replacing Toyota socket would be super easy. There is a wiring connection just behind bumper really easy to get at. 20 min Max to replace. Toyota eParts.com has them in stock.
Hensley Arrow
11-25-2016, 01:15 PM
I would agree with replacing to entire cable still easy but a bit more involved but finished product is a lot more secure. They also sell coiled 7 way cable really helps to keep it out of harms way.
Hensley Arrow
11-25-2016, 01:26 PM
do you have a Princess auto near you?
not sure if you have the ability to soldier and heat shrink the joints but its pretty simple to do. I cut my 5th wheel connector off and replaced the end with a new one from PA and spliced it into the existing in about an hour.
it took me longer to locate the reason who i had no turn signals of brake lights on my truck after I tore it off the 5ver.
4-Way 4 ft Trailer Harness | Princess Auto
5-Way 1-1/2 ft Trailer End Connector | Princess Auto
if you have a 7 way you can then pick up this adaptor
7:5-Way Trailer End Adapter | Princess Auto
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
11-25-2016, 02:16 PM
Call Japan.
11-25-2016, 09:18 PM
Check out Princess Auto!!!!
11-26-2016, 10:49 PM
Thanks all, I'll watch the videos and decide if I'm up to it! 😳
