Old 08-16-2016, 07:48 PM   #1
Why does the AC trip the breaker switch to a 120?
We have a 2016 270S Gas Georgetown Class A Motorhome that is plugged into our house outlet through a surgeprotector from MH and into a power strip in the shed. The AC was running just fine earlier in the summer but one day we turned on the bedroom AC also and it tripped the powerstrip breaker. We have turned off the bedroom AC but can't get the main AC to run without tripping it off also. Can we run the AC of the house 120?
rldself is offline   Reply With Quote
Old 08-16-2016, 08:32 PM   #2
Retired JSO's Avatar
Probably low voltage due to too small wire size in the shed. You should have a dedicated #10 wire circuit to supply electric without a voltage drop.
Retired JSO is offline   Reply With Quote
Old 08-18-2016, 02:56 PM   #3
Get a "Hard Start" Capacitor...
We had a similar problem and our residential AC man put in a "hard start" capacitor which boosts the compressor start. No problems since. Cheap if you do it yourself...$25 or less.
'13 Cougar 28RBS
Zixxer2Go is offline   Reply With Quote
Old 08-18-2016, 03:33 PM   #4
rracer5's Avatar
House 120 yes but, what amp circuit are you plugged into? You need a MINIMUM of 30 amps to safely start & run a 15,000 btu A/C (without potential damage to the unit). Running both A/C's would require a MINIMUM of 50 amps to start/run both A/C's (providing they would potentially try to start at the same time).
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 08-19-2016, 12:47 PM   #5
HalfBubbleOff's Avatar
I agree with the above posts. Voltage drop is your problem, when volts drop, amps go up. Run a dedicated 10/2 with ground and install a 30 amp outlet. This will only allow you to run AC at a time though. For a 50 amp outlet, you will need a 6/2 wire with a 50 amp outlet.
Ron & Ann
2016 Wildwood Heritage Glen 282RK
2015 Silverado 1500 5.3 355hp 3.42 rear gears
HalfBubbleOff is offline   Reply With Quote
Old 08-19-2016, 01:22 PM   #6
karrun's Avatar
20 AMP or 30 AMP circuit?
2016 Roo 21SS
2005 Ford Excursion-Sherman
Mods so far:
PI hardwired EMC, Wire Shelving in wardrobe
Plexiglass screen door protector, Blue LED Wine nook
stairs, and counting...
karrun is offline   Reply With Quote
breaker, switch
