Old 01-19-2016, 04:50 PM   #11
I never just run slides or jacks on battery power when shore power available last thing I do is level unit then put slides out or use gen set by the time U run the jacks and the slides the battery's. Are low not good. For the pump or motors
Blazer is offline   Reply With Quote
Old 01-19-2016, 04:57 PM   #12
You have given me great info and super links. It appears I have a converter issue, because I was plugged into 120v shore power but the batteries were not charged. They were fine 3 weeks before on our last trip. Thank you all. This is agreed forum, especially for a newly like me.
fdwarren is offline   Reply With Quote
Old 01-19-2016, 10:37 PM   #13
HerveVR's Avatar
We also have a 2012 Lexington 265DS, a real good MH to fit our needs.
After having to change last year's new batteries (under store warranty), we found the guilty apparatus: WFCO converter.
On 1/9/2016, ordered a new Progessive Dynamics PD9260C from Best Converter.com.
Should arrive within few days; just in time for departure dowm South to get old bones warmer.
HerveVR is offline   Reply With Quote
Old 01-20-2016, 07:53 PM   #14
Blackhat6mike's Avatar
The WFCO converter was the first thing to go in my unit in the first 6 months. Per the recommendation of my local RV guy [Newcastle RV in Brunswick GA] I ordered and installed a Progressive unit and have been very satisfied. I also use the Progressive 50 amp surge protector. That has saved us twice, once with a bad ground leg at the box. GFI kept kicking out. Checked the protector and sure enough, no ground.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
battery
