Old 03-02-2015, 09:26 AM   #1
Why you need RV Power Protection
After this weekends occurrence I am even more sold than ever that ALL RV's need power protection such as the Progressive Industries EMS. I am being careful not to say "surge protector" because a basic surge protector doesn't monitor for problems such as open ground, over or under voltage, reverse polarity, etc. With that being said, I installed the EMS-HW50C unit on our new Puma and started getting open neutral error codes. I got out the multimeter and started troubleshooting. Had ground continuity from the trailer side of the connection back to the ground rod at the pedestal. Had continuity to the inlet side of the EMS to the trailer outlets. Therefore, I knew the problem was at the inlet. Removed the inlet and discovered that the ground connection tab was broken off. It was broken cleanly, which was odd, but it pretty much had to occur during installation. Without the EMS, there is no way I would have ever known that the ground was not making contact. If a hot wire would have ever made contact with metal, it could've shocked someone. I attached a pic showing the missing ground tab.
Old 03-02-2015, 09:38 AM   #2
Thanks for posting this. Just reinforces to me that I made the right choice - I ordered an EMS-HW30C for our new Apex just this past Saturday. I will be installing it prior to our first trip.
____________________
2017 Silverado 3500 Z71 CC / L5P Duramax/Allison
2018 Grand Design Reflection 311 BHS
2015 Coachmen Apex 259BHSS 50th Anniversary (sold)
rjc1024 is offline   Reply With Quote
Old 03-02-2015, 09:46 AM   #3
geotex1's Avatar
Nice share dustman! I'm in the "on-board with that" category! It's cheap insurance that can be carried along unit-to-unit!
geotex1 is offline   Reply With Quote
Old 03-02-2015, 09:59 AM   #4
Ashley's Avatar
Ironically enough I just ordered my EMS-HW30C Saturday as well. It is something I had been putting off for a while and luckily have not been "Punished" for not having already installed one before now. I should receive it today and will be installing it in our 318BHS tonight when I get home.
I'm sure it will give me great Peace of Mind once it is in place.
2008 Dodge Ram 3500 MegaCab 6.7 Cummins
4x4, 4.10 Gears, 68RFE Trans
2012 Primetime Lacrosse 318 BHS
Ashley is offline   Reply With Quote
Old 03-02-2015, 10:10 AM   #5
I totally believe in them too. Never had an electrical issue, nor do I want one.
Old 03-02-2015, 10:19 AM   #6
Exactly. The Progressive units have lifetime warranties.
Old 03-02-2015, 10:21 AM   #7
This is actually the second thing I've caught with one. I had a 30 amp hardwired model on our first camper back in 2012 and it gave a reverse polarity error code. Discovered my pedestal at the house was wired reverse. Also, when I sold my 2012 Puma 30DBSS I removed that 30 amp model and informed the new owner it had been installed and he should consider one. Very first trip out they lost ground connection at the lake they were staying at and fried the inverter. Cost of new inverter would have paid for the EMS and he would have then been protected in the future.
Old 03-02-2015, 10:27 AM   #8
TURBS's Avatar
This thread should be a "sticky"
Moderators?
Old 03-02-2015, 10:36 AM   #9
KyDan's Avatar
Dustman-- is the photo of the socket on the side of your RV?
You say the ground lug is broken off but where is the ground wire???
Did they not even run a ground wire to the socket?
Peace!
Dan & Rita D
Old 03-02-2015, 11:30 AM   #10
Yes, it is the socket on the side of the RV. I uninstalled the connector and removed the wires during the process. The portion of the ground lug that was broken off was still clamped to the lug(?)a that you screw the wire down with.
Old 03-02-2015, 04:50 PM   #11
I couldn't agree more that power protection is a necessity. We have an EMS-PT30C from Progressive Industries. It not only protected us from a power overload while staying at a fair, Progressive Industries then replaced the surge module inside at no cost except shipping charges getting it to them. I will never be without.
MERV is offline   Reply With Quote
Old 03-02-2015, 04:55 PM   #12
Love RVing
Makes sense. We fried a coffee maker in a Ga State Park because 30 amp was wired incorrectly. Fortunately we were heating with propane or could have been more expensive. Also recognized a problem on AC unit at a NC State Park but was able to use their 50 amp connection there.
burse is offline   Reply With Quote
Old 03-02-2015, 06:14 PM   #13
Ddubya's Avatar
I built a new home last year with a barn to store my fiver. I ask the electrician to install a RV 30 amp circuit for my RV. After move in I plugged the RV into the outlet but had no power. I checked the EMS which I had installed earlier and it indicated a problem. After looking at the outlet I discovered it had been wired incorrectly. You would think that a licensed electrician would know better. Progressive EMS may have saved me from a serious issue.
2017 Alpine 3401RS,Titan Disc,Morryde SRE 4000, 2016 Ram 3500HD Laramie SRW,LWB,4X4, Aisin transmission
Ddubya is offline   Reply With Quote
Old 03-02-2015, 07:28 PM   #14
gashog's Avatar
Progressive Electrical Management System, Hardwire 50A/240V EMS-HW50C in Windjammer
Has anyone installed one of these Progressive Electrical Management System, Hardwire 50A/240V EMS-HW50C in a Rockwood Windjammer? Just wondering if there a problem with finding a space to install it.
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
gashog is offline   Reply With Quote
Old 03-02-2015, 07:33 PM   #15
gashog's Avatar
When you had the surge and the surge module blew, your vacation is over? on the flip side if you didn't have it your vacation is still over, but with the cost of replacing who knows what...
Old 03-02-2015, 07:52 PM   #16
geotex1's Avatar
No problem at all. Your power center is mounted in the island peninsula and there's room to the right side. Need to pull out the power center to install it as well as spend some time in awkward body contortions. Will need to use some flexible cable to make the bend out the "other side" of the HW50C and into your power center. I used Amcor marine cable because I have marine supplies every few miles around here... 3 feet was plenty. Installed one in 3029W for friends last October.
P.S. - Watch the 240V!
Old 03-02-2015, 08:00 PM   #17
TURBS's Avatar
Why would there vacation be over with the surge guard?
Old 03-02-2015, 08:02 PM   #18
TURBS's Avatar
Electricians think that since it a 30 amp plug "similar to a electric dryer" that it should be wired for 220 "like a dryer or welder" would be.
My guess is they don't know any better and uneducated about a 30 amp rv .
Old 03-02-2015, 08:07 PM   #19
geotex1's Avatar
In that case, seems the PI unit gave the ultimate sacrifice to save the life of what it protected...
Some happy campers lose their happiness when the juice dies!
Old 03-02-2015, 08:10 PM   #20
TURBS's Avatar
You can still bypass the ems and carry on like nothing happened.
Unless your afraid of the park power still lol.
TURBS
power
