Old 09-11-2014, 09:51 PM   #11
Let me also add that the trailer is using a WFCO 3 stage Converter/Charger. So float mode, aka trickle charge is 13.2V. So suspect it wouldn't gas that much?
2015 Keystone Raptor 425TS full body paint
TV 2015 RAM 3500 MC 4x4 DRW w/ AC69RC HD Trans
Pullrite Superglide 2300 24k w/ OE adapter 25k
cobiker is offline   Reply With Quote
Old 09-11-2014, 11:51 PM   #12
If it kicks down to 13.2v. I have read that the parasitic loads will keep it from "seeing" it's charged and keep going at 13.6v, boiling it dry. I think that's what happened to my batteries.
I have been checking every 12 hours or so, and after 2 days it did drop down to 13.2. I don't trust it yet though.
poorbuthappy is offline   Reply With Quote
Old 09-12-2014, 06:48 AM   #13
Witch Doctor's Avatar
Originally Posted by cobiker View Post
OK it found the following for a company called "PowerPulse" providing a device that "removes sulfation buildup on battery plates".
http://www.pulsetech.net//Assets/Pro...s//735X012.PDF
Is this it?
Yes that is it and it works as stated.....
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 09-18-2014, 09:56 AM   #14
DaveSchwartz's Avatar
I checked the voltage at the battery (on shore power) and its 13.2 volts so the parasitic loads are not enough to keep the converter from going to float mode. Since being in the battery box in the trunk is about the same as being in an unheated garage, I'll stick with the plan the just leave it plugged in.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 09-18-2014, 10:09 AM   #15
What brand converter do you have in the unit? If it's not a 4 stage for the money I would add the POWERPLUS that keeps your plate clean and burned off. For the cost it would extend your battery life, takes no power works off the battery juice itself. If you have a 4 stage then you don't need it, but 3 stage I highly recommend it for I think 35.00 bucks or so. Google Powerplus battery maintenance. See what you think... there's a link above at #13 post.
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-18-2014, 10:29 AM   #16
mark0224's Avatar
Now mind you gets a little colder here in NY where I am, Jan to end of Feb. can hit over night lows of -50 with wind chill. I bring mine in and keep it on a battery tender plus never set a battery on concrete and leave it I was always told it would damage battery. Your battery does a lot in your trailer activates trailer brakes if trailer brakes away from tow vehicle and for this reason alone you need a battery that is in good shape.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 09-18-2014, 10:38 AM   #17
KyDan's Avatar
Hook 'em to a battery tender and forget them till spring!
The new model battery tenders are transformerless and even more
efficient.
Peace!
Dan & Rita D
Blue Ox WD hitch
KyDan is online now   Reply With Quote
Old 09-18-2014, 12:24 PM   #18
WFCO.
Its "PowerPulse" (PP-12-L). Difficult to find or have shipped to Canada. Amazon.ca has the Wizbangplus, which claims to be the original. Might try either that or Walmart.com's 'ship-to-store' when we're vacationing in Florida in February.
Old 09-20-2014, 10:50 AM   #19
f5moab's Avatar
I vote for a battery tender and....
It is ok to leave the modern battery on concrete, brick, wood, carpet, etc.
The concrete thing was true many years ago (and I mean many) when the cells were glass enclosed in tared wood. Damp concrete could swell the wood destroying the glass cells.
f5moab is offline   Reply With Quote
Old 09-20-2014, 10:13 PM   #20
camaraderie's Avatar
Is this it?
FWIW...anything that claims de-sulfation/maintenance by pulse technology has been thoroughly discredited by actual independent testing. Don't buy the snake oil.
Dead Batteries After 8 Months? Surely Not! - Page 3 - Cruisers & Sailing Forums
I note that this comment does NOT include small maintenence chargers like the battery tender.
Finally...there is NO need in almost any climate for special care or removal of batteries for the winter PROVIDED that:
1. The batteries are FULLY...i.e. 100% REALLY charged...(not just a reading on a voltmeter when you turn the charger off!! )
2.Disconnect the negative wire and wait 24 hours and take a reading...if you get 12.6 or better you are good for 90 days of NO MAINTENANCE regardless of weather as the batteries will still be at 70% charge OR BETTER and STILL Good to better than 50 below.
Proof Needed?? http://www.trojanbattery.com/pdf/WP_...orage_0512.pdf
3. Make sure you get back to put a nice 100% charge on again if you have a long winter! And of course...check the water levels as you did before you left the RV in storage right??!! Bulk charging at around 14.5 volts is a LOT better for battery life extension than maintainers as far as desulphation goes.
If you have an Equalization cycle...use it as that is even better.
Per my link...a fully charged wet cell battery is good to 92 BELOW ZERO. And self discharge in below freezing weather is around 15% of the loss in 80 degree temps!
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
storage, winter, battery
