04-06-2017, 08:55 AM
Wire size for battery switch
Hello, i want to add a battery cut off switch to my camper. I need a wire that will go from the battery to the switch. What gauge should it be? Thanks for the help.
04-06-2017, 09:01 AM
The same size as the wire that today goes from the camper to the battery (the one you are taking off!) I don't mean this to be cute, we don't know what you have (number of batteries, ect) but the best guide is to simply get some more of what is there.
2015 335DS
at least 6 gauge , also depends on how far of a run , what's in use now for the battery supply ? keep it the same
04-06-2017, 09:09 AM
You can find pre-made ones of a variety of lengths at an auto parts store, usually #6. Or, you can just get a battery disconnect switch that mounts on the battery itself and you won't need any additional cables.
Like this: https://www.amazon.com/Post-Battery-.../dp/B001N729FS
2015 335DS
04-06-2017, 09:13 AM
Sorry. Its just 1 regular size 24 battery. I want to mount the switch on the outside of the battery box so i dont need much length. And im not sure what gauge is on there now.
04-06-2017, 09:16 AM
This is whats there not. I dont know how to tell what size wire it is. 2 maybe?
04-06-2017, 09:20 AM
This is whats there not. I dont know how to tell what size wire it is. 2 maybe? Attachment 133973
If you are simply going to mount the switch on the front of the box, it looks like there 'might' be enough to simply cut and add ends (that will fit your switch) to the existing wire.
May not need any!
04-06-2017, 09:21 AM
it's 6 gauge .
04-06-2017, 09:22 AM
May not need any!
I thought of that but there's not much slack in the cable there. It would make things a little tight i think. I would like to mount the switch on the top and i dont think theres enough wire for that.
04-06-2017, 09:23 AM
Originally Posted by northstar1960
it's 6 gauge .
Ok thanks! That helps.
04-06-2017, 09:35 AM
I'm pretty sure I seen some short 6 Ga. battery cables at Auto Zone the other day when I was in there snooping around. Only a couple bucks.
04-06-2017, 09:39 AM
Ok thanks ill take a look. Did it have the circle crimps on it already? My wire connects to the bolt next to the post so id need the bridge wire to have 2 circular connectors. Ill check amazon too. But thanks for the heads up.
04-06-2017, 09:43 AM
It did.
04-06-2017, 10:44 AM
Consider installing an inline ANL blade fuse to protect against shorts.
https://www.amazon.com/Link-ANLFH01-.../dp/B0002NRIKA
I have 300 amp ANL fuse going from each battery bank to the switch. This can protect against a catastrophic failure and prevent electrical fire. ANL fuse saved my bacon when a factory installed crimp on a general power distribution block came undone and the wire shorted against the frame.
04-06-2017, 01:05 PM
I'd recommend against installing it on the battery box top, unless you are planning on using an extra long cable and just tucking the extra length inside the box. Otherwise, it may get in the way whenever you want to take the lid off of the battery box. I'd mount it on the side of the box (if there's clearance), or on the trailer frame itself.
Eric & Abby
2016 Rockwood Roo 183
2014 Ford Explorer Sport
04-06-2017, 01:07 PM
I looked there. Unfortunately the battery is very close to the sides and theres not much of a gap. Once i get all the parts and get into it i will have to see what my options are. It might have to go on the trailer or frame.
04-06-2017, 01:22 PM
Ditto. Or step up one size or two. Auto parts stores usually have a selection of battery cables with gromet ends and wire gauges from 6ga up to 2 ga. I would use as short a wire and as large a ga as you can work with.
Best price on a cut off switch will likely be Harbor Freight or eBay/Amazon.
04-06-2017, 02:24 PM
google battery post disconnect and will find knife switch that attached to the battery post and then you just reconnect the wire to the switch.
04-06-2017, 02:26 PM
I bought that one first. Was too big and couldnt fit in the box. That why i have to make the change to external switch.
04-06-2017, 02:58 PM
That actually looks like 8 gauge to me but it is hard to tell. I know you said you wanted to mount it to the outside of the battery box but here is an alternative that is VERY easy to install. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Just take the battery box lid off and unscrew it to disconnect the battery.
Marc
2017 Wolf Pup 17RP.
2014 F150 1/2 ton Larait.
Lots of motorcycles.
