Old 06-07-2014, 05:38 AM   #1
GC
Wiring a 30 amp outlet
Needing a little electrical advice. I replaced the main service panel in my home and want to add a 30 amp RV outlet out of this main panel. I have wired the correct RV outlet with the correct gauge wire and have run the wire to the panel. Diagram shows black wire to breaker, white to neutral bar and the bare wire to the ground bar. Since this is the main service panel, the neutral & ground are bonded together and not separated like on a sub panel where they are seperated.
Do I just hook the neutral & ground wires to the neutral bar?
GC
GC
garycarson is offline   Reply With Quote
Old 06-07-2014, 05:43 AM   #2
Yes, GC, that's exactly what you do.
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 06-07-2014, 05:45 AM   #3
fonzie's Avatar
Black to breaker, white to neutral bar and bare conductor to ground bar. (this is the way that is done in Ontario, yours might differ)
Fonzie
Old 06-07-2014, 05:52 AM   #4
I think he is talking about a breaker panel where there is only one buss bar for the neutrals and ground. If that's the case, they go together. If there are separate ground and neutral bars they should go to their respective buss bars.
Old 06-07-2014, 05:53 AM   #5
fonzie's Avatar
Got it, true......
Fonzie
Old 06-07-2014, 06:37 AM   #6
Herk7769's Avatar
Main breaker panel has Neutral and Ground wires bonded.
Sub-Panels have separate buss bars since by code there can only be one bonded connection in a system.
HAM CALLSIGN - KC3FFW
Old 06-08-2014, 09:19 AM   #7
Herk7769's Avatar
Here is how to do it.
Just remember it is 110 volts no matter what your electrician friend says ()
Old 06-08-2014, 09:23 AM   #8
dcheatwood's Avatar
Good info. Is it the same for 50amp with larger gauge wire and 50a breaker?
Sent from my XT907 using Forest River Forums mobile app
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 06-08-2014, 09:29 AM   #9
Herk7769's Avatar
50 amp is different:
ID:	54629   Click image for larger version
File Type: pdf Top 10 Electrical Mistakes - Vol 1.pdf (452.2 KB, 65 views)
Old 06-08-2014, 11:31 AM   #10
Average Joe
MrJoe's Avatar
What size conductors are needed for a 30 amp, 30 foot run?
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
wiring
