Old 07-10-2014, 11:50 AM   #1
onetexasoldman's Avatar
Wiring for 2011 Brookstone front jacks HELP
My Tech is having problems with the wiring going to the control remote brain to the front jacks to jack motor. The brain was fried so we got a new one from Lippert. Lippert doesn't have any wiring diagram. Forest River doesn't have wiring diagram, Coachman Doesn't have wiring diagram DAH how do they make these?
I need to know where the wires go from switch (orange wire, red wire, black wire, white wire) Motor is reversable I know black and white.
Can anyone help or have a number I can call. My tech and I have all the places above with no luck.
If someone can look in there 5r and tell me what wires are connected it would help.
We think what fried the brain was the lift motor for the front jacks
2015 Bighorn 37' Front Living Room
2012 Dodge Cummins 3500 4x4
Live at 9000' in the rockies just out of Colorado springs
onetexasoldman is offline   Reply With Quote
Old 07-10-2014, 08:25 PM   #2
wingedone's Avatar
Again, confused. You have a pic of where wires go to the box. You need to know where to wires lead to?
2011 Brookstone 354TS
2013 F350 SC 6.7 DRW
Swivelwheel 58DW
wingedone is offline   Reply With Quote
Old 07-10-2014, 08:45 PM   #3
I am confused also but the tech has the wires on the box like the picture (he tells me) but can't figure out the wires to the front jacks switch. There are from what I remember a orange, white, red, black. He says the white should be ground but it's not. The white one is the one he is having trouble with, doesn't want to fry this box.
I know I asking alot but I need my trailer back and stop paying the $100+ an hour. I just need to know what colors are attached to each other from the switch to motor.
Old 07-11-2014, 07:04 AM   #4
wingedone's Avatar
The white wires in my unit are ground. They all go to ground.
I am sending you pics from my unit. I hope it helps.
Swivelwheel 58DW
Old 07-11-2014, 07:07 AM   #5
Thanks anything will help
Old 07-11-2014, 07:23 AM   #6
Thanks for the pictures! do you have hydraulic front jacks? I don't see the motor. You have the same year and model as mine and they have a whole different system. No wonder they don't have a schematic.
Thanks I will send these to my tech and see if it helps. What is the other box on the wall next to the remote mod?
Old 07-11-2014, 01:08 PM   #7
wingedone's Avatar
My front jacks are hydraulic (6pt system). But I do have the older version with the square tubes with pins to pull for the adjustable legs, not the round tubes.
The other box is this:
Swivelwheel 58DW
Old 07-11-2014, 01:14 PM   #8
wingedone's Avatar
My single hydralic pump (black) is on the right side, just above the hydralic tank (clear). It runs every hydraulic operation on the rig.
If you need more pics of something specific, let me know.
Swivelwheel 58DW
Old 07-11-2014, 02:39 PM   #9
Thanks for taking the time to take pictures. So you don't have a switch on the outside of the unit that would have worked your front jacks?
Old 07-11-2014, 03:35 PM   #10
wingedone's Avatar
Nope, no outside switch. I use the lippert pad for the 6pt and just the front jacks.
Check out here too:
2014 Blue Ridge 3715BH
You may have already seen this:
http://www.lci1.com/support/leveling...veling/levelup
Swivelwheel 58DW
jacks, roo, wiring
