Old 07-11-2019, 02:58 PM   #1
Wiring Polarity Identification
All of the Internal DC wires on my camper are white. On each pair one is solid white and the other is white with a color. I am assuming that the white with color is the Positive? I am wiring in some DC power ports and with some devices the Polarity matters.
2019 Cedar Creek 29RE
2017 Silverado Duramax 3500
rocco52 is offline   Reply With Quote
Old 07-11-2019, 03:24 PM   #2
D W
D W's Avatar
With the DC wiring on these rigs I assume nothing! To be sure I always use a digital multimeter to check the polarity. If your meter reads 12.8 then your red test lead is positive and the black is negative. If your meter reads - 12.8 then your meter is sensing a reverse polarity. That's the only way to know for sure.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator Mods- Reprogrammed 4L80E
2016 Salem 27RKSS (Pacific Northwest Build)
D W is offline   Reply With Quote
Old 07-11-2019, 03:46 PM   #3
Thanks DW, I did not know that a multi-meter would do that. Good to know!
cat, wiring
