10-04-2018, 09:28 AM
Wiring size and type
Not new to camping, just bought a 2019 Vibe 28BH. The small outside kitchen refrigerator on/off nob is on the back of the unit. The only way to access this nob is my removing a kitchen drawer and reaching in to turn the nob. I thought about making an access panel in the kitchen for it, but I think it would look terrible. The option I am looking at is running the outlet for the fridge to an on/off switch that I can access in the outside kitchen compartment. I can run the wiring from the outlet to the switch, but need to know what type and size of wiring to run from the switch to the outlet.
Thanks in advanced
Justin
10-04-2018, 09:48 AM
Is it 12v or 120v A/C?
A/C: I would use 12/2 romex
12v: 8 AWG should be fine
RETIRED U.S. NAVY
2017 FORESTER 3051S
IN SO-CAL
10-04-2018, 09:53 AM
Thanks!!!
Pretty sure it is 120v, but will need to double check
10-04-2018, 10:18 AM
To do it correctly, follow this diagram:
Where it says "break this tab", doing this will make the upper receptacle operate from the switch, and the bottom receptacle will have power all the time. I strongly suggest that you upgrade the current receptacle with a box and NEMA5 receptacle as well as a box and switch, all available at Home Depot or Lowes.
2016 Salem 27RKSS
10-04-2018, 10:23 AM
Junior Old Fart
Good drawing. Per code, run a ground wire to the switch also.
10-04-2018, 10:49 AM
Yes. I would also verify, because this receptacle is basically outdoors, that this circuit is controlled by a GFCI. Probably is, but you never know unless you check.
2016 Salem 27RKSS
10-04-2018, 11:03 AM
why not just flip the breaker ON when you want to use it? OFF when you don't?
10-04-2018, 11:26 AM
Probably not on its own breaker being a small fridge.
10-04-2018, 12:48 PM
If it is a on a 15 amp breaker, which I am almost certain it is, Just run 14 ga. No need to run 12 ga on a 15 amp circuit.
10-04-2018, 02:12 PM
What I did
I put a power bar mounted next to my fridge that I plugged into the outlet and then plugged the fridge into the power bar. Worked great, cheap, and quick.
2018 Rockwood 2509S Mini Lite
Past: 1984 Road Ranger 20', 1988 Kit Companion
1984 Starcraft 24 foot popup
TV: 1999 Dodge 2500 Cummins 4x4
Honda EU2200i Generator, 300 Watts Solar
Ham Callsign KD7UM
10-04-2018, 04:45 PM
Ut Grandpa, good job. Keeping it simple (KIS).
10-04-2018, 08:42 PM
It might, look in the power center.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
10-04-2018, 10:28 PM
Doesn’t the thermostat turned al the way down shut it off? The light would still work but the fridge would stop.
B and B
