Old 09-04-2015, 11:01 PM   #1
Unhappy Yamaha EF2000is surging & low oil light flickers
First post but long time lurker. I'm pretty bummed
I bought two EF2000is and a parallel kit from electric generators direct online. One of the units runs like a champ. The other has a rough idle and surges heavily under no load. Almost acting fuel starved. The oil light flickers which according to the manual is a sign of low oil.
I double checked the unit and it is full of oil. I'm upset because the website won't let me return the generator and the nearest service center is ~100 miles away. So much for my tailgating plans next week.
redas3 is offline   Reply With Quote
Old 09-05-2015, 07:50 AM   #2
TURBS's Avatar
Sounds fuel related to me.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 09-05-2015, 07:59 AM   #3
KyDan's Avatar
If it's giving a low oil warning the genny may be trying to shut down and since the low oil is flickering it would be sort of an on/off/on signal to the ignition. Are you SURE it is properly filled with oil???
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
Old 09-05-2015, 08:05 AM   #4
acadianbob's Avatar
Perhaps you have a faulty low oil sensor. See if the oil light flicker and the engine hesitation on related in timing.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 09-05-2015, 08:10 AM   #5
Assistant TP Supervisor
If the engine is stumbling the oil sensor might come on. I would dump the fuel and put some Premium in and try that. Works wonders on a lawnmower or weed wacker for me. I run Premium exclusively in my generators.
Old 09-05-2015, 08:11 AM   #6
TURBS's Avatar
No ethanol for sure!
TURBS
2011 32bhok Sabre
Old 09-05-2015, 08:12 AM   #7
TURBS's Avatar
After watching the video again I think your right, bad oil sensor.
I think I'd try switching the running gennie oil sensor in the non running unit.
TURBS
2011 32bhok Sabre
Old 09-05-2015, 11:50 AM   #8
Left Coast
Or, if 2 wires are going to sensor, hook 'em together and temp. by-pass sensor....Vented fuel cap? Open?
Old 09-05-2015, 12:33 PM   #9
TGR
TGR's Avatar
It appears, from the video, that the oil light comes on and the engine starts to die, which to me indicates it's the oil sender shutting down the engine rather than a fuel issue.
As KyDan recommended, check your oil level and top it off if necessary. Then turn the ECON.SW to off (0) and try it again several times. Maybe there is an air bubble in the oil system that will be forced out by the engine running at full throttle.
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
TGR is online now   Reply With Quote
Old 09-05-2015, 01:17 PM   #10
Since they are new I would be looking for an approved Yamaha service provider. You go in and start messing with it yourself you can kiss the warranty goodbye. Check the oil. Make sure you have fresh fuel, preferably
non-ethanol. If it's beyond that take it in with your proof of purchase showing when it was bought.
When I was in that field one of the first things we did was look for any signs of a unit being taken apart or altered from the factory settings. If we did, no warranty. It's amazing how many people think the warranty will cover what they have done to a unit.
2014 Coachman Clipper 17FQ
2011 Ford Ranger 4X4
Kenrod is offline   Reply With Quote
light
