Old 09-18-2012, 07:50 AM   #11
I downloaded the manual. I didn't see any reference to needing to ramp up the generator before putting a full load on it but it makes sense. On my Champion 2000w I need to turn off eco mode before using the microwave and hot water heater at the same time.
The EF2400is does not have an eco switch. Only way I know of to get it out of eco mode is as stated above.
I'll report back after I run Seafoam through it. Thanks.
hammick is offline   Reply With Quote
Old 09-18-2012, 08:25 AM   #12
Herk7769's Avatar
Oh! My Yamaha EF3000iSEB has an ECO switch and a warning in the manual about high loads applied while idling.
HAM CALLSIGN - KC3FFW
Old 09-18-2012, 11:28 AM   #13
Amazon.com: Yamaha EF2400iS 2,400 Watt 171cc OHV 4-Stroke Gas Powered Portable Inverter Generator (CARB Compliant): Patio, Lawn & Garden
Is this the one you have? Doesn't have an ECO switch, but does describe the "smart throttle" that varies to the load.
crasher is offline   Reply With Quote
Old 09-18-2012, 03:41 PM   #14
RPAspey's Avatar
I have an ef2400i also. what you described is spot on to what used to happen to me. my cure, 1 is to always use sea-foam in my gas. that alone made a big difference when I couldn't get alcohol free gas. 2 when you have to use the genny for a/c first make sure any side loads like electric h2o heater or fridge are on propane. then turn a/c fan to ON followed by turning on the a/c to cool. this in effect, ramps the genny up prior to a/c compressor kicking on. you could put the delay timer in the system, but I never had to.
BTW, those parasitic loads won't necessarily ramp up the genny from idle. I've been using my Yammy for about 5 years now without trouble.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 09-18-2012, 03:45 PM   #15
TURBS's Avatar
You must not use the auto function on your a/c then ?
So you leave your fan on 24/7 ?
Old 09-18-2012, 08:16 PM   #16
RPAspey's Avatar
no, not on 24/7. it seems that once the camper is cooled down it can run as normal. but we rarely need to run the a/c for a long time.. as in an hour or so max.
Old 09-18-2012, 09:53 PM   #17
Yes that is my model. I believe the smart throttle is having problems ramping up fast enough to handle a large load. I will see if seafoam helps.
I believe it has the factory jetting. I called the guy that sold it to me. He lives in Missouri and bought it from a guy in Minnesota.
Old 09-21-2012, 07:19 AM   #18
ryand's Avatar
I have the newer version of the 2400. The auto throttle is a bit clumsy... Sometimes you are on the lip of needing it so it will hunt for the right rpm. Mine starts my a/c but I do need to run the fan for a while prior to starting the a/c. From your description the unit is running fine.
Have you changed the oil as well? Never know where it's been!
2011 Coachmen Catalina 28DDS
2015 Ram Bighorn 2500 6.4L
http://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
Old 09-28-2012, 02:15 PM   #19
I ran a tank of seafoam through it and also sprayed carb cleaner on all the jets and the choke. It helped but didn't fix it. I found that if I apply a tiny bit of choke it runs great and will not surge. I adjusted the choke cable and now all is good. I need to do a final test on some gas without seafoam.
BTW I installed the hard start capacitor on my AC and now the 2400is will power it up just fine without having to ramp it up with the microwave first. I can even start the AC with the fridge running.
The 2400is does seem to hunt around a bit. Sometimes applying a small load will actually lower the RPMs. I will play with it without Seafoam next time I have my trailer in my driveway and report back.
Thanks for all the replies.
Old 10-01-2012, 10:47 PM   #20
Cmmjmoore's Avatar
Is there a website or how to book on generators and rv's? I have had salesmen tell me all kind of things related to finding the right generator for your camper. Our SP 240 is running a 13500 AC unit, with the water heater which I could run on LP so that just leaves the microwave and 12 volt lights But the Honda guy said I would need the 3000. What I am reading here is you are running a similar rig on a 2000. I dont mind spending the money for the right size, because that seems to me to be better than listening to a 2000 labor with a load. Confused.
2013 SP 240 Anniversary
Tundra CrewMax 5.7L in Pyrite Mica
Clark, Mary Jane & Max our German Short-haired Pointer
(2011-42)
Cmmjmoore is offline   Reply With Quote
Yamaha
