Old 04-27-2015, 01:24 PM   #11
TURBS's Avatar
Correct me if I'm wrong but 2
A/c units and converter alone max out the two gennies?
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-27-2015, 01:24 PM   #12
13.5 a/c. It was night, so no lights were on, I even switched the frig to propane and it was still overloading.
I will get a volt meter and monitor that.
2009 Chevy Silverado 5.3L Z71
2014 Salem 281QB
tmas is offline   Reply With Quote
Old 04-27-2015, 06:06 PM   #13
Should I be more worried about Volts or Amps?
Old 04-27-2015, 06:18 PM   #14
B and B's Avatar
tmas, do both generators quit? I am wondering if the parallel setup has an issue? Does one generator speed up at all, like a fuel supply issue. This could cause the load to be transferred to one generator causing it to stop. Are you running premium fuel with stabilizer as well.
In order to test the current you need a breakout and a clamp on ammeter, something best left for a electrician.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-27-2015, 08:20 PM   #15
It would vary, sometime both would overload, other times one of them would not be running.
Both were filled with regular gas (87 octane).
After this weekend I ran stabil through both generators and changed the oil.
2014 Salem 281QB
Old 04-27-2015, 08:41 PM   #16
Witch Doctor's Avatar
I agree with B&B there must be a problem with your connection.
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-27-2015, 09:35 PM   #17
Other than gas, what can I check on my generators or dual power cable?
Thanks again for all the help.
Old 04-27-2015, 10:03 PM   #18
B and B's Avatar
Maybe your parallel kit is not working correctly. Check the small pins on the plugs for arcing and make sure they are not black or look like welding has happened, might be brass in color with the nickel plate worn off.
Old 04-28-2015, 12:54 PM   #19
I will look at my candles tonight. When connecting the banana plugs, do they lock in place?
2014 Salem 281QB
generator, heating
