Old 04-26-2015, 06:38 PM   #1
Yamaha generator - overheating?
I run 2 Yamaha 2000 generators. This pass week the generators keep overloading. I turned everything off but the A/C. The generators would run fine for an hour or 2 before overloading again. In reading the manual, the overload light could also indicate overheating. This seems more likely.
Thoughts?
What can I do to avoid overheating.
Thanks!
Frustrated in Texas
2009 Chevy Silverado 5.3L Z71
2014 Salem 281QB
tmas is offline   Reply With Quote
Old 04-26-2015, 06:52 PM   #2
Are you running more than one A/C unit? It COULD be that you are running too large of a load. Those units aren't meant to run at max output for extended periods. Ie., they are 2000w units, but extended rated output is only 1600 (if I remember correctly). I forget what the surge output and duration is now... but I know max is 2000w, rated output is 1600w, and in parallel you're limited to 3600w.
rana is offline   Reply With Quote
Old 04-26-2015, 06:55 PM   #3
One unit. It runs for a while and then cuts off, but no when it kicks on, just randomly stops. I turn off the A/C. Turn off the generators. Restart the generators. Turn A/C back on and then I'm good for anywhere from 30 minutes to several hours.
2014 Salem 281QB
Old 04-26-2015, 06:59 PM   #4
TURBS's Avatar
I don't think you can run two a/c units especially in hot weather.
Your pulling down 3600 watts alone with just the a/c units.
Converter is also drawning another 600 to 900 watts.
One a/c at a time.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-26-2015, 07:10 PM   #5
toslow's Avatar
did you check the oil level in the generator?
haven a blast
toslow is offline   Reply With Quote
Old 04-26-2015, 07:57 PM   #6
HONDAMAN174's Avatar
Had a similar problem last weekend where my honda 2000 would randomly shut off but restart no problem. Took a while to notice the oil shutdown light. Oil seemed pretty full but added a bit more and got thru the weekend without any more issues.
Just glad to get away
Old 04-27-2015, 12:33 PM   #7
Check the manual for oil specifications. In hot weather or running near capacity, there is usually a secondary oil viscosity specification.
Provide shade for the generators when they are operating.
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 04-27-2015, 12:53 PM   #8
Thanks. I changed the oil after this weekend.
One more thought, what should I do with my battery when my generators are connected? I am leaving the battery's connected so that is pulling from my generator too.
2014 Salem 281QB
Old 04-27-2015, 01:12 PM   #9
jeff64's Avatar
I would be interested in knowing how many Btu AC you are running. 13,500Btu shouldn't be a problem for the two gensets. BUT, what else are you running at the same time on the generator? Do you have a plug in voltmeter that stays in one of your TT outlets at all times? If,not, suggest you spring for one. Charging a battery at the same time through the converter shouldn't be a issue. Running refrigerator and a bunch of non led lights might get you overloaded though. The voltmeter will tell you whats happening. If you can't pull 110vac whilst your load is on the generator, you got a problem with too much stuff on
Old 04-27-2015, 01:22 PM   #10
Witch Doctor's Avatar
I agree here is a chart of amps things pull then figure out what you can run without overloads.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
generator, heating
