Old 05-07-2016, 10:05 AM   #1
TsnTexas's Avatar
Zamp Solar pre-wiring question
I have a new Rockwood 2504s which is pre-wired for one of the Zamp solar panel kits. The only visible component to this is the externally mounted plug and I'm wondering what might be already installed if anything between this plug and the battery besides a couple of wires. Are there any other components related to the charging system? i.e. fuses, charge controller, etc.
2016 Rockwood 2504s
2016 Chevy 2500HD
TsnTexas is offline   Reply With Quote
Old 05-07-2016, 09:50 PM   #2
friendofacatahoula's Avatar
No charge controller. Two wires which on ours does not go directly to the battery, goes to the junction box first and will not charge unless battery switch is on so no good for using as a tender. No visible fuses.
Ours was also wired opposite of a standard two prong plug from our existing portable solar combo but so was our exhaust fan lol.
friendofacatahoula is offline   Reply With Quote
Old 05-07-2016, 11:59 PM   #3
dmchapman's Avatar
Correct. The Zamp plug is wired reverse polarity. I wired my Renogy directly to the battery with the controller in a front storage compartment. Haven't figured out a use for the Zamp plug yet. Maybe I'll plug my 12V Christmas decorations into it next Winter.
dmchapman is offline   Reply With Quote
Old 05-08-2016, 03:52 PM   #4
TsnTexas's Avatar
Thanks for the input, I've been looking at the Renogy and would also make a direct battery connection.
2016 Rockwood 2504s
2016 Chevy 2500HD
Old 05-09-2016, 12:52 PM   #5
I too have a Renogy solar suitcase solar panel set. I use the Zamp wiring. It is very convenient. I think Zamp purposely wires their setup opposite the usual polarity so they can put on the sticker that says you must use Zamp only. The solution is simple. The output cable from the Renogy can simply be connected to the controller in reverse polarity - you have to connect it via screw terminals out of the box anyway, then it will work normally when connected to the Zamp wiring. The Zamp connector is a standard SAE connector, same as comes with the Renogy product.
hunterrick is offline   Reply With Quote
Old 05-09-2016, 03:25 PM   #6
zamp
Have a Zamp on my Sunseeker
This goes direct to the battery / same as if you connected an outside source with clips .
I did not buy a Zamp but connected to color panels for battery maintenance no issues
stervin is offline   Reply With Quote
Old 05-09-2016, 04:29 PM   #7
Some guy in back...
On the connector, could be, but it might also be that they did not want an end user to have an exposed pin (from a large panel) carrying 12+ volts, ready to short and cause bigger problems...
So, marketing and safety at the same time!
ChateauV10
SF Bay Area
'99 Ford E350 V10
'16 Rockwood 8329SS
ChateauV10 is offline   Reply With Quote
Old 05-10-2016, 12:22 PM   #8
I use my zamp plug as an outdoor charging station for my phone or whatever, works great!
I put solar on the roof running through a controller inside (I installed) way better and cheaper then zamp.
2016 Rockwood Ultra Lite 2604WS
2004 Dodge Ram 2500 CTD 5 speed Manual 4x4 Laramie
2005 Ford Mustang Convertible
1993 Jeep Wrangler YJ IL6 4.0 lifted (love it)
Happy Trails All!!
roaddiva is offline   Reply With Quote
Old 07-08-2016, 06:57 AM   #9
ilmor's Avatar
Can you describe how the zamp plug is used like this in laymans terms? Also what connector is used, and how. A pic would be great too!
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 07-08-2016, 08:04 AM   #10
Sky&Scuba
kendive's Avatar
Buy your own connector and set the solar panels like you want with a charge controller.
2 Pins Power Industrial Connectors Waterproof IP67 Male Plug Bayonet Connection | eBay
I ordered on already.
2015 F150 3.5 EcoBoost Lariat FX4 502A 3.55 Gears Max Tow KO2 Tires
2017 Grand Design Imagine 2150 RB / Traded in Catalina 253RKS
kendive is offline   Reply With Quote
solar, wiring
