I can tell you what I just started using a few months ago, but can't vouch for it's longevity yet. I have several cordless 18 volt Ryobi tools that were purchased from Home Depot. Ryobi also makes an air compressor that uses the same batteries. I have used it several times with no problems and what I liked is that you can set the air pressure you want for the tire on the digital scale, then the compressor shuts itself off when it reaches that pressure in the tire.
It also does good in putting air in inflatables at the lake. It's also light, small, and portable. You just have to make sure you have charged batteries.
As I said, it was cheap to purchase since I already had a few batteries for the other tools, but may not be if you have to buy a dedicated battery/charger to go with it.
Ryobi 18-Volt One Plus Cordless Green Inflator-P731 at The Home Depot
